post #1 of 1
I'm in a process of finishing my basement and I'm trying to figure out a way to sync my outdoor speakers to the basement in-ceiling background speakers and I have to do this wirelessly (I only use this for "net based" listening like Pandora).
My current setup:
-Zone 2 on Onkyo TX-NR609 is hooked up to a 5 way splitter (with volume control), 4 of 5 are used for outdoor speakers
-I'd like to use the signal from #5 and transmit it wirelessly to an amp which is ~40' away in the basement (going through 2 walls & a ceiling)
I've been searching around and it seems that Amphony makes a product that would do exactly what I need but I've also read some bad reviews about them so I'm a bit skeptical.
Any advice or suggestions would be appreciated.
