AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Does a normal Digital Optical Coax Coaxial Toslink to RCA Analog Audio AUX Converter support a 5mm Toslink cable?
Does a normal Digital Optical Coax Coaxial Toslink to RCA Analog Audio AUX Converter support a...
post #1 of 2
Converter:
http://i.ebayimg.com/t/New-Digital-Optical-Coax-Coaxial-Toslink-to-RCA-Analog-Audio-AUX-Converter-/00/s/NTAwWDUwMA==/$(KGrHqVHJCME+,Iwd7j+BP4Fd9vMo!~~60_12.JPG
Toslink:
http://www.pccables.com/02603.html
post #2 of 2
Support a what? The one you list likely only supports digital PCM 2.0 to analog 2.0.
