AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Sub choices for around 1500?
post #1 of 4
So thanks to some on here it looks like the final 3 choices are as follows to bring low end into my 24x17 theater room.
Svs ultra 13
Rythmik f15hp
Or 2 psa xv15s
I would think 2 would be better than 1 but what is everyone's opinion on these and what would you all go with focusing primarily on HT. And I am running DT 8060 towers with 300 watt subs built into those if that matters at all.
post #2 of 4
Starting place is 2 subs centered on opposite walls and start adjusting from there.
post #3 of 4
One Rythmik FV15HP or 2 PSA XV15's imo. The Rythmik is a better sub, but 2 XV15's well get ya similar low end extension down to around 16-18hz depending on room gain and more midbass(40-63hz)...not to mention dual subs will help smooth the bass output.
data-bass.com/systems
add rougly 6db to the xv15's numbers if the 2 subs are co-located.
Edited by basshead81 - 5/8/13 at 9:33pm
post #4 of 4
2 XV15s. In a large room, you need multiple subs.
