AVS › AVS Forum › Video Components › Home Theater Computers › Setting up my 360HD drive to work with XBMC
post #1 of 5
I'm not sure if I should have posted this here or in the DVD drive section.
I have a HTPC(really just a desktop) connected to my AVR790 and 55 lm6200. The front of the PC is full of lights and pretty ugly amongst the rest of my components. What I want to do is put the computer behind and use the 360's HD DVD drive as the DVD player. I got it working with Media player within windows 8 pro. But XBMC doesnt recognize a disc being inserted. Wether it be HD disc or regular DVD. But it works in file mode, which is no solution for the wife to use
Any ideas?
post #2 of 5
You could just open the case and pull the LED connections from your PC's motherboard, or just use black tape.
post #3 of 5
Ya, I thought of that. But it's an ugly acer all in one. I should have just built one form scratch like I always have. But it was so damn cheap LOL.
Plus I like the idea of playing all my HD DVD's and many regular dvd's
post #4 of 5
I have now got XBMC to recognise the HD DVD player. I turns out I had to disable the internal drive, not that I am using it anyways. Re arranging the drive letters within windows would fix the problem too.
Now, I am still struggling to get HD DVD's to play. XBMC Frodo pukes at the attempt LOL. I know PowerDVD 7.3 plays them, but it's long gone.
post #5 of 5
Good luck with the HD DVDs. You'll probably need Total Media Theater, or simply rip them to something more XBMC friendly.
