AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Bic F12 vs PL200 vs PSW505
post #1 of 6
I'm considering between F12 and PSW505 and reading through the forums, I see F12 would be better for watching movies(which I would be doing the most). Also I see PL200 is recommended over F12 on a higher price range.
Now I'm torn between F12 and PL200 over $60 price difference. Would it be worth spending more on PL200?
Thanks for your time!
post #2 of 6
Out of those 3 subs I would definitely go for the PL-200...
Although another sub around that price range that is considered to be even better than the PL-200 is the Klipsch RW-12d from http://www.newegg.com/Product/Product.aspx?Item=N82E16882780078 it sometimes goes on sale for $280 to $300.
post #3 of 6
Thanks i looked in to klipsch@newegg but all recent reviews complain about receiving defective ones or with broken parts. It kind of put me off as I don't want to deal with returns.
post #4 of 6
I don't know about other people's experience but we recently received a RW-12d from Newegg and no problems.
post #5 of 6
Agreed. PL-200 or RW-12d is a much better choice than the BIC F12 or PSW505.
post #6 of 6
Hmm, I should check the size of the pl-200. I'm looking at similar priced subs, but possible dual sub
