AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Just bought Sony STR-DN1030
post #1 of 3
I havi impared sight and I am having difficulty with the setup, everyone knows that the GUI is bad, and somewhat unresponsive and the manual is even worse, that having been said, can I use 4oHm speakers in the rear. I think the receiver is rated at 8ohms, will 4ohms overdrive the amp?
Edited by Ken Malinak - 5/9/13 at 10:21am
post #2 of 3
4 Ohms loudspeakers should work fine..
Key points are:
1. Brand/Model
2. Specs for sensitivity, should be @ least 88dB/1M, 1W
As long as one keeps the volume levels reasonable.
Just my $0.02... 👍😉
post #3 of 3
Thanks for your response.
