AVS › AVS Forum › Display Devices › Display Calibration › Klein's Software Update Released
post #1 of 3
Klein ChromaSurf 5.2.403 (09 May 2013)
Release Notes
Changeset Logs:
* Fixing hardcoded RGB matricies.
* Esc will exit out of measurment
* Added Manual Entry Device
* Check devices that are unplugged and close them
* Create Cal will stay infront of the background form
* Fixed not connecting to some serial to USB devices on MAC
* PC Pattern Gen works with muit montiors
* Added signing text for windows
Unknow issues:
* Mac Lion (version 10.7): Fullscreen problems
Tested Linux platforms:
* CentOS 6
* Ubuntu 13
Download Link
post #2 of 3
Klein SDK Package: v2.35.194 Oct 10, 2013
Release Notes
Major
* Added DCI-P3 Gamut
* replaced WhiteSpec with GamutSpec
* Added FootLamberts to Nits and back
* Added Hue and Saturation
* Flicker to 150HZ on new devices
Minor
* Be able to compare GamutSpecs
* Fix flicker crash
* Fixed memory leaks
* Added new correction for flicker
* Added hue, staturation, value, gamutSpec to AvgMeasurement
* Added Docs for GamutSpec
Download Link
Edited by ConnecTEDDD - 10/28/13 at 7:16am
post #3 of 3
Klein ChromaSurf 5.6.458 (17 December 2013)
ChromaSurf is updated to be compatible with newest Mac 10.9 (Maverick) Operting System (as of 17/12/2013).
Latest Version: Added Features
* New GamutSpec window
* Kelvin Calculator: Hue and Saturation graph
* Pattern Manger: Changed max stable time for the pattern Gen to 15 sec
* Flicker: Added 3 error indicator
* Pattern Manger: Added a Manual Pattern Gen
* General: Added nits/fL to all the values
* Settings: Removed Flicker from setting
Latest Version: Bug Fixes
* CreateCal: Fix Select Cal from going in the background
* CreateCal: Only one instance
* CreateCal: Fixed a Unit
* Flicker: fix going to old 100 instead of 150 when connected to the new firmware
* Pattern Manger: Users cannot change colors doing a run
* Pattern Manger: Doesn't hide form after finished
* General: Changed the text on unstable measurement error
* General: Resizing Hue and Saturation better
* General: Fixed FL and Nits conversion.
* Mac: Doesn't crash on load
* Linux: Doesn't crash on ESC in pattern run
Latest Version: Tested Linux platforms:
* CentOS 6
* Ubuntu 13
Download Link
