AVS › AVS Forum › Audio › Receivers, Amps, and Processors › HT 5.1 receiver with HDMI + front LR preamp out ?
post #1 of 12
Need a receiver with all that -- HDMI in and out + front preamp outputs -- asking because the search is driving me nuts.
Anyone know of any ? Don't want want megadollar "audiophile" (gag) stuff.
post #2 of 12
I've never seen a receiver with preamp outputs on the front. doesn't mean one doesn't exists but I've never seen one.
What can't you just run the preamp outputs from the back? connect a dual rca extension cable from the back and run it under the receiver to the front as most receivers have a 1/2" to 1" of clearance underneath.
http://www.amazon.com/Cables-13040-Velocity-Extension-Meters/dp/B0002J1TUE/ref=sr_1_2?s=electronics&ie=UTF8&qid=1368286729&sr=1-2&keywords=rca+audio+extension+cable
Edited by afrogt - 5/11/13 at 8:42am
post #3 of 12
Yamaha a820
Sent from my iPad using Tapatalk HD
post #4 of 12
The A-820 has aux inputs on the front, lots of receivers have those.
post #5 of 12
front L and R preamp outs.
not on the front panel !
post #6 of 12
A-820 has what I need but ouch on the price -- nice because it has all 5 preamp outs.
post #7 of 12
post #8 of 12
Oops my bad! There are lots of receivers with preamp outputs. search shouldn't have been that hard. They are more mid level than entry level though.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882117412
post #9 of 12
The low end Marantz models have 2.1 pre-outs ... 1403 (MSRP $399) and 1504 (MSRP $499).
post #10 of 12
ok thanks -- may need to just get in my receiver and add my own. another thing if anyone sees this, off topic though -- has anyone seen a receiver with HDMI inputs and will supply whatever HDMI video you're watching at either a composite or S-video output?
most of the receivers I've searched will only output an analog video input.
post #11 of 12
AVRs don't do HDMI--> analog video down conversion.
post #12 of 12
thanks JDS -- sure looks that way -- bought an HDMI to S-video converter the other day that I hope will work out.
