AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Need help deciding on which Sub or Subs to purchase!
post #1 of 5
Hi everyone,kinda new to this site and thread trying to get some input on which sub or subs to purchase for my HT,the room I will be using is 12x26 with 8 foot ceilings,its a living slash dining room that opens up to the kitchen. The front mains are Polk 75Ts the center is a Polk monitor 25c and my surrounds are Polk monitor 65Ts,any input would be Appreciated!!!
post #2 of 5
budget?
what will the sub(s) primary duty be? music or movies...both?
have you considered duals for that size room?
post #3 of 5
I would say my budget is around $500.00 for the sub or subs,Im powering my system with an Onkyo tx-nr809 and is a power conditioner really nessesary?
post #4 of 5
Oh and my system will be 80-20% Movie/Music!
post #5 of 5
if you can swing 600.00 I would go with dual Klipsch RW-12D's from new egg. They are probably the best bang for buck sub. I do not think there is any single sub around 500.00 that will pressurize that room. The Rythmik LV12R might get you close, it runs 589.00 shipped.
