AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Best 65" plasma for gaming (input lag/PQ)?
post #1 of 12
Hi,
I will be using the plasma entirely for gaming. My main concern is input lag and PQ.
Price not really a factor...but I am not obsessive about calibration and/or reference quality.
I play a lot of FPS games but im not really super hardcore... but when i play i want the best PQ possible.
I play in a dark room.
Which plasma should i buy?? Will any of the 2012-2013 Panasonic plasmas be ideal for me? I know to stay away from the ST60 due to higher input lag!
Thanks, guys !!!
post #2 of 12
The S60 I had read has acceptable input lag and less than the ST60, I don't know how it compares to other models from this year though.
post #3 of 12
S64 from Costco. Best option.
post #4 of 12
65zt60
post #5 of 12
vt60 or zt 60
post #6 of 12
If money is no object the VT60 followed closely by the ZT60 .....
If you want to keep it under 3K than the S64 or the S60
post #7 of 12
i know zt60 is like the best PQ right now but can i really justify spending $4,000 on the 65" model? money isn't really an issue but it's the principle of it... and especially since i probably wont notice much difference in game mode.
i am thinking perhaps i should go with the lowest input lag model...? is there a list of all plasma input lag specs?
also, maybe black level is also an issue with games. which tv has good detail in blacks??
post #8 of 12
Sounds like I may go this route.
post #9 of 12
The 'S' series has the lowest input lag measured of any 2013 Panasonic model, which is great for gamers (34.1ms measured by CNET w/ Leo Bodnar)
post #10 of 12
S60 is probably the best option for low input lag and semi-acceptable brightness. Last year's U50/U50 is also ok, although they're dimmer.
VT60 would be the second best as it also has low input lag but I do not know if you're going to like its ABL.
ZT60 would be the third best...same input lag as the VT, but dimmer.
Me..I will be waiting until the next year's models come out. Samsung F8500 turned out to be perfect, ST60 near perfect, but both are marred by terrible input lags.
post #11 of 12
I bought the s60 65" and returned it. Great for gaming but i found the pq wasnt all that great (cnet settings) on cable hd channels.
Im picking up the 60" VT60 sometime this week and ill let you know how that compares.
post #12 of 12
well, my current TV is a 42" LCD from 2009: LG 42LH30
im sure any of 65" panasonic plasmas will blow me away (PQ wise). i havent been gaming on current console systems since their graphics are so poor but now with next-gen consoles getting ready to release... im looking for a new TV. biggrin.gif
