AVS › AVS Forum › Other Areas of Interest › Camcorders › duplicating a dvd
duplicating a dvd
post #1 of 2
after making a dvd in x4, what's the easiest way to go back later and make copies of it. I make them for a local race track and when I run out I need to make more. So far I have not found a way to burn another dvd without re-doing the whole menu. Is there a way?
post #2 of 2
Welcome to the forum. I assume you mean Corel VideoStudio? Did it come with Corel "DVD Factory Pro"? It should be under the tools menu in VideoStudio. You can use the "copy" option from "disc to disc" in DVD Factory.
  Back to Forum: Camcorders
