AVS › AVS Forum › Display Devices › 2.35:1 Constant Image Height Chat › DVD players with vertical stretch
post #1 of 7
I have an Oppo BDP-83. The disc tray had an issue a few years back. Oppo fixed it for free even though it was out of warranty. Thank you Oppo. Now it refuses to play Blu-rays, loads then reports "no disc". Tried multiple Blu-rays. It plays DVDs. Oppo support replied to my service request, I reset and reloaded firmware to no avail. Oppo wants $79 to fix. I'm wondering if money isn't better spent by buying a new player. Not sure I want to stay with Oppo, great service, but then I only know that because of issues with the player. frown.gif
What other Blu-ray players are highly recommended and can do vertical stretch?
Search only turned up a 2006 thread.
post #2 of 7
No replies????
Well if anyone is interested, Oppo came through with flying colors. I am local to Oppo, dropped it off about 11 AM. by 3PM I had a call that it was ready. Oppo rocks!
post #3 of 7
I only know of the OPPO BDP-103. I picked up a refurbished one for $415 though I don't see it on their site anymore so it might be sold out for the time being.
It looks like you got it fixed so it may be a moot point.
Does the 83 doe the v-stretch too?
post #4 of 7
How do you like the Oppo 103, with verticle switch, are using a lumgen or anamorphic lens?
post #5 of 7
Awesome! So many features and very well built. Solid like a tank. It doesn't feel like plastic and fragile as many other cheaper players do. If you've ever seen the Toshiba HD-XA2 HD DVD player (which I also own), it would be on par w/ that. Top of the line for it's class.
It's definitely worth the investment!
I use a Panamorph 480 Anamorphic lens and have no issues so far. The remote has a button for zoom and the first setting is for vertical stretch. So very easy to use w/ out having to go in to a menu to turn off and on. And it works in 3D mode, which many projectors that have vertical stretch don't.
What's your setup? What are you trying to do?
post #6 of 7
AFAIK, only OPPO does a vertical stretch. PHILLIPS offers ST shift like the OPPO.
post #7 of 7
I have the Sony hw50es projector.. wanting to either the lumagen or cinvista lens on a 150 dalite pearlescent screen.. trying to make head and tail on what to purchase fir 1st time buyer.. dar room black ceilings dark grey walls..
