AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Dayton 12 subwoofer wiring ?
post #1 of 7
I just got my Dayton 12 power subwoofer .
My ? is my receiver has one rca sub output . This subwoofer has two line level inputs L & R . The direction says for mono Connect to R input .
Also it has a note - If a LFE mono output is connected , set the crossover point to max.
Not sure what to do here .
here is the receiver I have Sony STRDG 500
http://www.docs.sony.com/release/specs/STRDG500_mksp.pdf
Thank you
post #2 of 7
Do what the directions say.
post #3 of 7
i have dayton 1200 too. you can put the rca in either one of them. it doesnt matter. yes set xover to max if you ran audysey.
post #4 of 7
Max the frequency. Your amp should take care of everything else. Just connect a 'Y' cable OR use the 'R' input. Either way, it will be correct. wink.gif
post #5 of 7
I see you have the rw12 AND the 1200. Could you please go to this thread and give your impressions of the comparison?
http://www.avsforum.com/forum/newestpost/1471965
post #6 of 7
BTW...His Sony amp does not have Audyssey. Either way, the xover should be maxed out. wink.gif
post #7 of 7
Thank you
