AVS › AVS Forum › HDTV › HDTV Technical › Antenna A will not show picture or sound or menu
post #1 of 3
I have a pdp5080hd. When i go to my hdmi inputs and components everything works fine. When i go to antenna a to watch tv my screen is blank, no volume, channel, or anything. I cant get to the menu or anything like that. If someone could help on what to do i would greatly apprecitate it thanks!!!
post #2 of 3
Are you missing the Remote control??? If you can't get to the menus, either you need to carefully reread the User's Guide or your firmware needs to be reloaded. Let's hope it's something simple:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/477134695PDP5080HDOperatingInstructions0807.pdf
post #3 of 3
Did you set the Mode switch at the bottom of the remote control to TV?(p15)
Are you trying to watch TV chanels from cable or antenna?
Have you done a channel scan using Auto Channel Preset?(p37)
Edited by rabbit73 - 5/14/13 at 11:06am
  Back to Forum: HDTV Technical
