AVS › AVS Forum › Audio › DIY Speakers and Subs › Noob in need of knowledge
post #1 of 4
Hey guys I am wanting to learn more about crossover design and construction and I would like to get any recommendations you have for good reference material on the subject. All input is appreciated. Thanks in advance!
Greg
post #2 of 4
I've learned a lot from zaphaudio.com. Also, a lot of people recommend Vance Dickason's Loudspeaker Design Cookbook. Also check out various forum FAQs. Ask questions on the forum. Attend a diy meet if you can. Helps to have a background in science and math. Build a speaker design and reverse engineer it. Build one from a designer with an open line of communication and ask them all about it. Ask them how they did it.
Good luck.
post #3 of 4
http://techtalk.parts-express.com/showthread.php?219617-The-Speaker-Building-Bible
Best compilation of info imo. Designing a good speaker isn't something you can just jump into without gaining extensive knowledge and experience...
post #4 of 4
Thanks for the info. I have a bachelors in math so I think this will be right up my alley. Thanks again for the help:D
