post #1 of 1
I have a 56hm66 DLP TV and I started getting a blinking power light after use of 3 hours or more.... In the manual it says that it is an abnormal BUS operation line... so I unplugged it and plug it back in and it its fine until use of 3 hours or more then it starts to blink again.... i did a self diagnostic check and it gave me the results of
error 1: tuner
error 2: AVSW
error 3: APRO
error 4: MTS
error 5: SDA low
error 6: SCL low
error 7: DMD engine
error 8: thermo sensor 1
error 9: thermo sensor 2
the only thing that I do know is going bad is the bulb ... can anyone help me with this problem
