AVS › AVS Forum › Video Components › Home Theater Computers › MB3 in Public Beta
MB3 in Public Beta
post #1 of 193
The MediaBrowser team has just released 2 components into the wild, MB Server and MB Classic - see here http://www.mediabrowser3.com/2013/05/15/and-were-off/#.UZPzyaLvuCJ
post #2 of 193
I didn't realize they were going the route of My Movies with a server/client model.
post #3 of 193
Yeah - and very snappy it is too.
post #4 of 193
So if you have movies on two different computers that right now are listed by their network path in MB Configurator those will now be aggregated by installing MB Server on one machine, which does not have to be the same machine that MB is on. Am I reading this correctly? Will the MB Server allow for network shares?
post #5 of 193
Is there a way to have mb3 classic open movies with mpc-hc?
post #6 of 193
I was told it could support external players
post #7 of 193
AFAIK yes
Yes MBClassic is just a newer version of the old MB, but which continues to support WMC integration - MBTheatre which will provide a stand-alone playback engine is still in development.
post #8 of 193
Hah... another Plex-like contender in the making...
Except for the fact that this is only windows based at the moment...
Hopefully they will consider porting to Linux at some point in time...
post #9 of 193
Very interesting....I just downloaded the 6 month trial of Windows Server 2012 Essentials and finally ordered my Supermicro server from Tams....looking forward to see how the server version of MB3 works out!
post #10 of 193
I do that now, works same as MB2 did.
post #11 of 193
Sorry steelman, didn't notice you made this thread after posting in the other thread.
post #12 of 193
A few screenshots of the web view.
And more as I scroll down...
post #13 of 193
No apology necessary Fanta - response was aimed firmly at Mfusick lol.
post #14 of 193
msfusick has not posted in this thread.
post #15 of 193
Post #6
post #16 of 193
Mine just opens in wmc. Is there a setting in mb3 to make it use other software for playback like in mb2?
post #17 of 193
Yes, there is a MB config still for the things that need to be setup locally. Client settings of mb classic have to be different, but not for everything. You obviously didn't have to setup your library, a few plugins or preferences locally, but things like gamebrowser would and of course the external player preference in your case.
post #18 of 193
As Fanta poiints out there is an MBClassic configurator which works in almost the same way as MB2 (particularly for external player set-up)
Edited by steelman1991 - 5/16/13 at 11:23am
post #19 of 193
I am curious in how well the server version of MB3 works out since it means one wouldn't need to have MB on each HTPC. I downloaded the server version but won't have the time to test it out until the weekend. Maybe if those who are testing the Server version can report on how well it is and how quick it is for info, that would be great. I'm going to install this on my new server on WS2012E once I get things set up and squared away.
post #20 of 193
Definitely something I'll be keeping an eye on, but my system is working too well right now to want to use a beta. Definitely interested in seeing other people's impressions though.
post #21 of 193
It is pretty great so far though I'd recommend putting clients on your htpc's. Maybe wait awhile though before replacing whatever else you
post #22 of 193
Have installed.
I have mb server port forwarded and it is really cool how I can view a full bluray at work. ..on a web browser.
post #23 of 193
Have installed.
post #24 of 193
Any status update on availability for iPhone or iPad ?
post #25 of 193
Have installed.
Speaking of this, keep in mind that you will want to put the server software on a PC with a decent processor if you plan to use the web client at all. The transcoding takes a fair amount of processing power. Originally I had it installed on my Windows Storage Server which had 2 vCPUs and I could only run at "medium" quality settings. I moved it to my desktop PC which has an FX-8120 processor, and now I can watch at "ultra" quality. Transcoding a blu ray will consume about 40-50% of that cpu. I would say a quad core is minimum if the web client is to be used. The CPU requirements are the same as before for any client that does the video processing locally.
Also keep in mind that for Windows 7 machines you can put the server and client on the same machine. Apparently this will not work with Windows 8 last I heard due to the way MS implemented the local loopback, but they are looking into it.
post #26 of 193
It's in beta, but it likely isn't ready for public consumption yet. There isn't a lot of discussion on it. Apple doesn't make it easy to distribute beta software that you don't want pushed to the store.
While on the topic of client releases. It is my understanding that they wanted to clean up a couple of things on server, and then they were going to focus on MB Theater which is the client that has the built-in player. I am anxious to see how well that works.
Edited by brianjb - 5/17/13 at 6:18am
post #27 of 193
Yes Brian - luke has said he intends to move on MBTheatre as soon as he sees a drop in the number of reported issues on Beta Server.
post #28 of 193
post #29 of 193
Have installed.
I agree with all this...I have mine installed right now on a win7 vm and it's been great so far. Cpu doesn't get too high but I haven't monitored it much as there haven't been skips or anything.
post #30 of 193
Heh, ya I can't wait either. Mb classic is fine and all but mb theater should bring a lot of new enhancements.
