AVS › AVS Forum › Video Components › Home Theater Computers › MB3 in Public Beta
MB3 in Public Beta - Page 4
post #91 of 193
Release Candidate 1
post #92 of 193
The new control feature.
While browsing via the dashboard of the server, the control button allows you to do multiple things.
The first of which is select your media and play it where you want.
You can also get as specific as certain chapters.
This is just the first take on it as it was recently added, I am sure they will add some more neat commands for the control.
It's very fun to use as well as handy...say your parents are at home..."I CAN'T WORK THE DAMN TELEVISION!!!"...you hop onto your pc from anywhere and play for them what they want...magic smile.gif.
post #93 of 193
That's awesome
post #94 of 193
Originally Posted by Mfusick View Post
what is "RC1" ?
It's a way for software developers to continue to "beta" software but make it appear that progress is being made towards the final release. It's supposed to be that essentially everything is complete for the needs of that release and things as they are right then have the potential to be what is the official release. If there are any bugs found, they should be relatively minor and hopefully not have a significant impact on the software version.
Edited by cdru - 6/13/13 at 10:14am
post #95 of 193
did you mean to quote his RC1 question?
post #96 of 193
Doh. Yes.
post #97 of 193
Honestly- The idea of playing something from my PC when my wife wants to watch something in the living room and is struggling is just awesome. I like that.
post #98 of 193
Its a very awesome feature. I can browse my library on my tablet sitting in my theater... I click "Play on MB3 Classic" and viola, the command is sent to MBC and the movie starts playing.
post #99 of 193
any idea about losless playback from this. or will you have to use a external player.
post #100 of 193
In Media Theatre 9 (not yet in Beta) VLC will be internal but with the option to use external. MB Classic can use external same as MB2
post #101 of 193
That's a good question actually I haven't even thought to test out my FLAC material. Currently everything in MB-Classic I am using MPC to play videos and stuff.
I am waiting to really evaluate the internal player once MB-Theater is getting released. That will have the new player with that. MB-Classic is just pretty similar to MB2. For FLAC I use the WMC internal player plus reclock to bypass Windows audio.
post #102 of 193
I haven't been able to fined through a search but I believe VLC will not bit-stream loss-less.
post #103 of 193
Currently I don't believe it does, but there was comment from one of the MB devs that they hoped it would be in place very soon, if not for launch of MBTheatre.
post #104 of 193
How does one access the server from a different PC (or even outside of the network)?
I have no problem accessing SABNZBD, CouchPotato or Sickbeard from another PC. Just not MB3 Server...
post #105 of 193
Are you just looking for the port#? That plus the machine's IP address is all you need. 8096=local and 8945 for off site if I recall correctly.
post #106 of 193
I'm really jazzed about the standalone solution. I always found 3d iso playback buggy for me if I used mb2 and wmc, but if I used the standalone tmt5 application it was fine. Hopefully MBT will solve this problem.
post #107 of 193
What is the lastest on the time table release schedule ?
post #108 of 193
MB-Theater I hear is getting real close to beta testing...some recent teasers:
A much, much easier way to install plugins vs the old way of leaving mediabrowser.
post #109 of 193
I hope so i am having serious issues right now. I am posting this here because it might be a Server Issue or a MC Client Issue. I get a lot of randomly freezing. If i am using the Media Center Client it will lock up and it is at varying times. If i am using the web client it will only freeze for a few seconds. I am using a gig network, and these are full blu ray rips that use to play fine using xbmc. I am using sharks codec pack and have tried a couple of different settings.
post #110 of 193
That's interesting. I think you will have much better luck at the mediabrowser forums.
http://community.mediabrowser.tv/permalinks/13652/mb-server-public-beta
They are typically VERY good at getting back to me with any issues I have seen.
post #111 of 193
Any word on when the theater release is set to beta test ?
post #112 of 193
Thought I would post some recent screen shots of current builds...
Media Browser Server...
Media Browser Classic...
Media Browser Roku...
Media Browser Android...
More to come...
post #113 of 193
Is there an ETA of the app for the iPhone or iPad remote control?
post #114 of 193
Good day,
Not yet, but the dev for iOS working and come with some good info about it.
My best
post #115 of 193
The app is being designed for IOS7. The target is to get it out in the app store for IOS7 launch.
post #116 of 193
when I visit the site ie 10 locks up causing a three finger solute, anyone else having such issues ?
post #117 of 193
I accessed it without a problem in Win8 IE10
http://www.mediabrowser3.com/download/
post #118 of 193
So for some reason I can't find where to change the theme. I installed the 3 free ones to test .....
post #119 of 193
Possibly a dumb question, but is there any way to actually import MB 2.6's data into this? Most important for me would be to keep the watched vs non-watched status, but everything else would be nice as well.
post #120 of 193
I'm assuming you're using MB Classic.
You can change it through the settings within the Media Center interface:
CFC
