AVS › AVS Forum › Video Components › Home Theater Computers › need advice for blue screen
need advice for blue screen - Page 2
post #31 of 37
go into device manager click on display adapters and what does it say?
post #32 of 37
intel (R)HD Graphics
post #33 of 37
did u install the Intel graphics drivers yet? by any chance are you able to reproduce the blue screen at will? if not run with the new drivers for a while and see if it has solved your problems. please do report back I'd like to know how this turns out for you
post #34 of 37
Mmyeah those bsod's looked to be caused by the Intel graphics driver.
After you have cleaned the old drivers off of the system and installed the newest put Driver Verifier running for a day or two.
http://www.sevenforums.com/crash-lockup-debug-how/65331-using-driver-verifier-identify-issues-drivers.html
If no issues arise consider it solved.
post #35 of 37
here's what I updated
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22521&lang=eng&OSVersion=Windows%207%20(64-bit)*&DownloadType=Drivers
can't reproduce BS.
I will diffinitly report back w/ results.
actualley I'm not sure if I cleaned old drivers off.
I did'nt logicalley remove them.
I just did the above update.
STB
post #36 of 37
Your graphics are built into your Intel i3 550 CPU (has an integrated GPU). You have the basic Intel Core HD Graphics.
post #37 of 37
I haven't used the HTPC for about 5 weeks now just started using again for about 5 days w/out the BCOD.
here's a image the the BSOF
if compared to the example in post # 1
notice there is'nt a top code.
maybe the #ed codes will revelve exactly whats happening?
I just want to be prepared if the new graphics driver did'nt resolve this issuse.
STB
