AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Sony [X9] XBR-55X900A / XBR-65X900A Owner's Thread
Official Sony [X9] XBR-55X900A / XBR-65X900A Owner's Thread - Page 86
post #2551 of 7375
Originally Posted by hatlesschimp View Post
I spoke to Sony and the store I got it from. The store is going to get in another TV for me in and then deliver it to me and I will hand the delivery man from the store the old tv. - Early next week some time all this should happen.
That´s good news, maybe you want to take your laptop to the store and check the new set right there before delivery to your home, you don´t need to take out the TV from the box, just pulling up the top box and taking down the protective bag you can turn on the tv and check the uniformity with the laptop, If the new set is good, ok, take it home, but if it is not, give me a refund. When I can, I always do this, its a time and headache saver. wink.gif
post #2552 of 7375
Originally Posted by AustinJerry View Post
With a backlight setting of 3, what is the Luminance measurement?  I get a Luminance of 42 with a backlight setting of 7.  IMO, Luminance is a preference setting, and my target for my low-light viewing room was 40 or higher.
As mentioned in a previous post, Gamma=0 produces the best results on my set.  Otherwise, no significant difference between our settings.
Funny, I get 42 ft-L with a 100% pattern and backlight at 3. Mine is the 55" though.
post #2553 of 7375
Originally Posted by sports fan View Post
OK all, I bought a 100 ft cat6 cord on the way home last night and ran it from my router downstairs to my Sony FMP-X1 upstairs. Perfect sizzling connection at 35mbps. Fired up the TV & media player.....
Nothing.
Same error on TV. Cannot connect to media player. Tried it with the TV network wired and wireless. So it's definitely not the network.
To quote Dr. Emmitt L. Brown, "My God. Do you know what this means? It means that this damn thing doesn't work at all!"
Any ideas on my next step?
Yes, it has nothing to do with your network. That error is misleading. Disconnect everything from your TV from all your HDMI ports except for the 4k server. Also disconnect the HDMI port 2 cable from the 4k server. Turn it on with both TV and 4k server being on one network connection. It should work now.
The 4k server has knows issues if you have Directv GENIE DVR connected to any port. This unit has to be fully off for the 4k server to work. On mine, there is issues even if my receiver is plugged into HDMI port 2 on the TV. Sony is aware but is saying the issue is with Directv and they have to solve it.
On a bright note, anyone check out that Bicycle movie.. that is the most visually stunning 4k movie that I have seen
post #2554 of 7375
I'm not having any issues into HDMI 1 although I am passing the genie through an AVR first.
post #2555 of 7375
Originally Posted by wase4711 View Post
RIP plasma tv's, you served us well...
---That article did say, "When reached for comment, the company said that nothing had been decided." I bet plasma tech has 1-2 years left in plasma . However, no real improvements.
post #2556 of 7375
Yeah, I am sure they have to build out what ever inventory they have left, and sell it off...at least the prices should drop until all the products are gone..
post #2557 of 7375
Im calibrating a whole bunch of settings under different scene selects.
They do not stick.
Im positive for cinema 2 I had color at 45, now it's moved on it's own. I also had picture at 80, it's now on max etc...
Any way of saving these settings so they do not move?
post #2558 of 7375
change input from current to common
post #2559 of 7375
This!
post #2560 of 7375
doesnt anyone read the owners manual anymore? Most of these questions are so easy to find the answers to...
post #2561 of 7375
They do not stick.
When you select Options, Scene Select, you are presented with a list of scenes (cinema, sports, etc.). If you select Sports, for example, and then go in and change settings for that mode, the settings should be preserved for Sports. Now if you go in and select Cinema, and then look at the settings for Cinema, the settings should be different from the ones you set for Sports. That is the way it works. There are some settings (e.g. white balance) that are global settings, and will apply to all scenes. Go back and try again and report your results.
post #2562 of 7375
who keeps the owners manual HAHA
post #2563 of 7375
who reads anymore?
post #2564 of 7375
I READ THE I-MANUAL WHICH IS NICE I GUESS
post #2565 of 7375
well, if you have to return the tv, or ever sell it, you might regret not having it..
Originally Posted by ashhos View Post
who reads anymore?
Ah, you hit on the core problem with this country now a days...
very handy; I print out a manual and keep it in the TV room; I grabbed the pdf, and put it on my tablet for easy viewing, and, of course, having the owners manual available at all times by pushing a button on the remote is a fantastic feature on this TV!
post #2566 of 7375
That's what I do.
I change settings in each category. For example, In Cinema 1 and 2 (under cinema scene select) I have Sharpness and color set to 45 specifically.
When i go back to that category the settings have changed.
post #2567 of 7375
Not sure I understand all this CURRENT, COMMON ETC
It seems when i go to auto, or the one underneath ...24 something....if i then go on vivid...It kills all the cinema settings in the cinema scene.
post #2568 of 7375
Not following you at all, sorry.
post #2569 of 7375
There is a ton of good information in owners manuals.
post #2570 of 7375
ok so you choose the scene select first in this case cinema, the you hit "options" on the remote and then you go to "picture adjustments" first option on the top will be "Setting Memory" press it and then you can choose between common or current input where "common" will be the one that saved for all the inputs.
post #2571 of 7375
ABBAS!! I am giving you a cyber- BJ!
Your solution was 1000% correct. I unplugged the DirecTV HDMI cord from the TV, turned on the 4k media server....and worked like a charm! Unbelievable!
I must've spent 40-50 hours trying to solve this. THANK YOU!!
Sony needs to put this warning on its website. Good god.
post #2572 of 7375
So, do you have a DTV Genie DVR?
post #2573 of 7375
I'm sitting within the screens narrow boundary but even so, the left side of the screen is brighter than the right. On the green Motion Picture Ratings screen the right side of the screen has deeper color than the left. There is also a purplish tint on a black screen. This and the too narrow viewing angle is too distracting. You have to sit right in the middle to get the best picture and that is not acceptable. I already had one replacement TV. I'm going to contact Sony today.
post #2574 of 7375
So you can only choose ONE common setting?
How do you save multiple settings?
Edited by quovadis123 - 10/11/13 at 5:22am
post #2575 of 7375
Yes I do indeed have a DirecTV genie DVR. How Abbas was able to instantly recognize that is amazing.
post #2576 of 7375
The settings are per scene...but common across all the inputs when the common setting is turned on. This way Cinema/Game/Sports all have their same respective settings (per scene) on HDMI 1 and 2 if they are both set to common.
post #2577 of 7375
I'm having trouble trying to buy a movie off the 4k server. I've entered my credit card information on the sony network entertainment website, but keep getting an error message on the server when trying to purchase a flick. Is there something else I need to do? Thank in advance.
post #2578 of 7375
I wonder what is different with the Genie? I have two networked HR24 DVR's, and they don't cause any problems with the Media Player.
post #2579 of 7375
Can someone using a pc on this tv help me please?
In the invidia Control panel i can see the Sony tv.
What resolution should i set it to?
4kx2k 4096 x 2160 ?
4kx2k 3840 x 2160?
4kx2k 2048 x 1536?
4kx2k 1920 x 1140 ?
4k x2k 1920 x 1200
I tried the HDMI 3 into the Sony, and it says no signal. I was using the highest resolution 4096x 2160.
Any ideas?
post #2580 of 7375
I also tried 1080 x 1920 on hdmi 4 input of sony.
just got weird lines
The output is the HDMI on my Titan gtx card
