AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › Best Attic-Based Antenna For 50 mile Sensitivity
post #1 of 21
O.K., I know that this is not the appropriate forum for posing this question, but it's the only forum which will have me as a member, so I'll flout authority and ask anyway: Comcast has finally encrypted and STB'd my local channels, so I'd like to put an antenna in my attic to receive HDTV signals (from only one direction) that are circa 50 miles away. Can anyone suggest such an antenna (preferably from Walmart so that I can return it if not optimal)?
post #2 of 21
My Walmart store now carries an attic antenna. Check your store?
I'm pretty sure this online one is the same as in-store.
Might need an amp?
One reviewer said he didn't get 3 channels with this but switched to the amp'd RCA antenna for 4-cents more (this one?) and got them all.. however, it says it has a lower advetised ("over 30 miles") range?
Edited by wajo - 5/18/13 at 10:12am
post #3 of 21
Thanks, Wajo
post #4 of 21
SUBJECT: 50 Miles From an In-Attic Installation is PUSHING IT!!!
Originally Posted by JimLely View Post
...I'd like to put an antenna in my attic to receive HDTV signals (from only one direction) that are circa 50 miles away. Can anyone suggest such an antenna (preferably from Walmart so that I can return it if not optimal)?
  1. Go to "Antennaweb.Org, enter your address and find out what type of antenna they suggest.
  2. Per my conversation just this afternoon with a Solid Signal Tech, DOUBLE the distance (i.e. up to 50% signal loss from attic vs rooftop installation). So, now you're DEEP FRINGE (i.e. 100+ miles).
  3. Check the available channels displayed on Antennaweb.Org.
    Are they:
    1. UHF only?
    2. UHF plus High-VHF?
    3. UHF plus both High-and-Low-VHF?
IMHO, the antenna LINKed by wajo is a waste of your money. frown.gif Just by looking at it, I'd guess that it's UHF ONLY, good for up to 25 miles IF rooftop mounted.
50 miles from an in-attic installation is pushing it, again, IMHO. You'll probably need a pre-amp too.
Take a look in: Local HDTV Info and Reception and see what other folks in your neighborhood are using. Go to SolidSignal.Com, enter your Zip Code and see what folks in neighboring towns are buying. Forget about department store B&Ms (i.e. Walmart, Target, RadioShack). You need a SERIOUS antenna! eek.gif Get multiple opinions BEFORE buying!! wink.gif
Post your Zip Code.
post #5 of 21
I wonder how many other localities have had all their cable channels scrambled per the new FCC rulings.
post #6 of 21
"...have had..." and WILL. I'm guessing that most cable companies are going to transition to 100% scrambling now that they can. We all better get used to it. frown.gif
post #7 of 21
Run a TV Fool report and post it here. On the results page it will give you a url to share. It won't reveal your exact address.
post #8 of 21
All that's left in my Comcast neighborhood is a few local analogs, no more QAM what so ever frown.gif
post #9 of 21
I GOOGLE'd "Zip Code Naples FL", got 34101, and entered it in all the sites I found by more GOOGLE'ng. He's got a straight ~45 mile run north. Transmitter Profile Detail shows vertical peaks between the transmitters and 34101, ending in green. Most of his channels are yellow, indicating attic install permissable. But, with ~45 miles, I'd go with a 70+ mile antenna to start due to the "up to 50% loss from attic install"..
Antennas Direct 91XG UHF TV Antenna (91XG)
Luckily, all the major networks are UHF, closely grouped just north of Fort Myers Shores.
I'm surprised that although the OP has logged in multiple times since my reply, he hasn't posted his results. confused.gif
post #10 of 21
It looks more like a Popular Mechanics project... I mean 50 miles eek.gif... fortunately for him, there aren't many natural obstacles, like mountains. Anyway I guess that won't be a cheap installation, but I support and will be following this thread.
Good luck!
post #11 of 21
post #12 of 21
Technical Data Antennas Direct 91XG Antenna:
Dimensions:
Length = 93 in.
Width = 20 in.
Height = 22 in.
Turning Radius: 52 in.
post #13 of 21
Well, on the bright side, at least it will eliminate all the Clear QAM tuning problems with the funai DVD recorders.
post #14 of 21
Oh yes, we can all take great solace in that.
post #15 of 21
www.diytvantennas.com/sbgh.php
I made 2 of these 6 months ago.Both are hanging on the wall.
What ever you do
TEST on a windy day.
Right now wind is up to 30mph here in atlanta.
Mom is watching NETFLIX during this windy day.
Streaming "Jesse Stone".
Mark
post #16 of 21
SUBJECT: What's the Status of Your 'Attic-Based Antenna' Project?
Hi JimLely!
I noticed that you re-visited this forum yesterday (Magnavox SUPER Thread - Post #23793), but you still haven't replied to THIS thread from 05/18/13 regarding your 'Attic-Based Antenna' Project. frown.gifredface.gif
post #17 of 21
post #18 of 21
SUBJECT: Personally, I Find It Rude...
Personally, I find it RUDE when someone CREATEs a thread, multiple forum members RESPOND, and then the OP User, although logging onto the AVS Forum MULTIPLE TIMES *AND* replying to OTHER threads since the date of this OP, doesn't bother to reply to this one. redface.gif
Well, EXCEPT for the:
Thanks, Wajo
I, like CitiBear for example, take quite a bit of MY PERSONAL TIME to both RESEARCH and POST an intelligent reply. Thus, IMHO, the COURTESY of a reply from the OP User is expected... mad.gif
post #19 of 21
delete this thread
post #20 of 21
Maybe JimLely can't get the local building licenses for his project. frown.gif
post #21 of 21
I'm sorry guys but I never realized that there were other responses after Wajo. (I only visit the Maggie thread on this forum.) I'm now reading all of your responses for the first time. I never thought that this misplaced (by me) topic would generate these well-thought-out responses and I am (belatedly) deeply appreciative of them. My sincerest apologies.
I haven't done anymore on this topic since Comcast has not yet (even though they said they had) implemented this change, and that my probability for success in the attic location is so low. I also have DTV so the only channel I really need from Comcast is WGCU-DT2, a PBS alternative station.
Again, my apologies,
Jim
  Back to Forum: DVD Recorders (Standard Def)
