AVS › AVS Forum › Display Devices › CRT Projectors › Identify VPH-1020Q deflection yoke
post #1 of 3
http://diy-community.de/attachment.php?attachmentid=93228&d=1296667669
Can anyone tell me which part of that picture is the deflection yoke, and how I would rotate it? The picture on my green tube isn't level.
post #2 of 3
It's the one butted right up to the bell of the tube. There's a radiator hose type clamp that holds it in place. Loosen it, and you should be able to rotate the yoke, but there's usually sticky tape between the yoke and the tube neck for friction, and the yoke and tape usually are badly bonded by now, since they've been paired for about 25 years. smile.gif
You can either forcefully rotate the yoke, and it will usually snap free of the tape, or you might need to take all the magnetics off the tube by partly pulling the tube out from the front, and sliding a small straightblade screwdriver between the yoke tabs and the tape, which will break the bond.
post #3 of 3
haha thanks Curt. I asked here to avoid bothering you with another question and you ended up answering anyway.
It turned like a champ, and my problem's completely fixed now.
  Back to Forum: CRT Projectors
