AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Bricked LG 42pj350, lg mode 1.6.10 on firmware 3.32
post #1 of 44
I flashed Firmware 3.32 (downloaded it from the official site) on my LG 42PJ350. After update I put lg mode lgmod_10610.epk. After that TV got reset, picture appeared for a moment and than the screen went dark. Now the TV is like dead, not responsing on the Remote Control. If i connect the power cabel it makes 2 times "klick - klick", red LED goes on for a moment and picture is just dark gray.
Tried to connect with serial cable rs232, did everything read on the forum, but nothing happend while I was pressing ESC, no boot mode. What is the problem? Is the u boot locked or am I doing something wrong… if it’s locked, is it possible to unlock it?
post #2 of 44
Try pressing MENU on the remote and MENU on the TV; hold the buttons for 10 seconds and see if a service menu appears.
post #3 of 44
post #4 of 44
So, in a dark room, does the screen glow?
Are you OK to take the cover off and do some tests -- The main board or control board are replaceable, and I think that one of those is causing the issue.
post #5 of 44
Yes, sreen glows in dark. I'm OK to take the cover off and do some tests
post #6 of 44
Yes, whilst the boards are probably physically OK, in my opinion, one has firmware corruption and perhaps the only way to fix this is to replace said board.
post #7 of 44
We checked the main board and control board with the multimeter, and them seems to be ok. What do you think, which one I have to replace? Is there anything else I can do before replacement?
post #8 of 44
How did you "check the board with a multimeter"?
post #9 of 44
My father did it, has experience with older TVs...
post #10 of 44
There's very little you can check with a multimeter on a modern main board. In the middle of the set there is a green board marked CTRL or similar. Can we have a picture of that? There's a jumper connection you can make which will tell you if the fault is in the main or control board. I'm leaning to the main board at the moment due to the screen glow.
post #11 of 44
i will put the pictures tomorow...
post #12 of 44
http://i.imgur.com/oSSqE5w.jpg
http://i.imgur.com/18HG82q.jpg
http://i.imgur.com/aCNFeUd.jpg
http://i.imgur.com/610ehAk.jpg
Edited by rokibalboa - 5/23/13 at 11:00am
post #13 of 44
I'm interested in the board right below the power supply in this image.
Edited by tom669 - 5/23/13 at 11:49am
post #14 of 44
post #15 of 44
OK, see the points marked EXT AUTO GEN? Two holes... Place a 100 ohm to 470 ohm resistor between them (any value from 100 ohms to 470 ohms is OK.)
Unplug the connector which goes between this board and the main board (which has HDMI, SCART, tuner on it.)
Turn the TV on. Do test patterns appear?
post #16 of 44
Main board is replaced, TV working...Thank you for help
Edited by rokibalboa - 5/29/13 at 12:13am
post #17 of 44
I have the same problem with the same TV an LG 42PJ350
Where do you buy the main board?
Cost?
There is another cheap option to solve the problem?
THANK YOU from Spain
post #18 of 44
I`m me again
I find a Hard Reset on the service manual, but where is located on the TV?, I don't know how to read
post #19 of 44
Cost?
Did you locate the test pattern jumper and see if you got test patterns first?
Main board replacements can be found on eBay, and on other sites such as ShopJimmy.
post #20 of 44
Thank you for answering!!!
No, How I can do this?
Main board replacements can be found on eBay, and on other sites such as ShopJimmy.[/I
For example this?
http://www.ebay.co.uk/itm/EAX61366607-0-PD01A-EBT60974107-LG-42PJ350-ZA-MAIN-BOARD-/281112510373?pt=UK_Sound_Vision_TV_Boards_Parts&hash=item41739c7fa5
post #21 of 44
There are two points marked EXT AUTO GEN on the control board. Simply take a piece of wire and bridge them together. Then, disconnect the cable between the main board and control board and power on the set.
Control board:
http://i.imgur.com/8d2eKec.jpg
Main board:
The replacement you linked to looks suitable.
post #22 of 44
These are two holes, I connected them without power supply, after I take off the wire between the main board and the control board, but nothing happens.
Are you shure we must connected them without the power supply?
Thank you for everything
post #23 of 44
Sorry, where are you disconnecting the power supply?
The only cable that should be disconnected is the one between the main board and control board. That's just one cable. All others should be left in place.
Then after placing the jumper, the TV should be powered on.
post #24 of 44
Hello, thank you for your patience.
1.- With the power supply on, I put the wire between the two holes
2.- I disconnect the cable between the main and the control board
3.- tried to power on the TV pressing POWER ON in the remote control and in the TV at the same time, and hold on for 10 seconds, nothing happens
4.- tried to power on the TV pressing OK in the remote control and in the TV at the same time, and hold on for 10 seconds,nothing happens
5.- tried to power on the TV pressing MENU in the remote control and in the TV at the same time, and hold on for 10 seconds,nothing happens
6 connect the cable between the main and the control board and repeat, 3, 4 and 5, and also nothing happens, the TV NEVER has the led on, or/and the screen on
nothing happens, my TV continues sleeping, a deep sleep
Ferran Torregrosa
post #25 of 44
Ah, so with the power plugged in, do you have any standby indicator at all?
post #26 of 44
No, nothing
Maybe I'm doing something wrong, but i do the procedure 3 times....and with the same results...
Any indea?
THANK YOU FOR YOUR HELP
post #27 of 44
Since you have no standby light, the next test will require a digital multimeter - do you have one?
post #28 of 44
Yes I have one...
Tell how to do...
Thank you
post #29 of 44
connector1.jpg 820k .jpg file
Can you get a closer picture of the highlighted area?
post #30 of 44
Hello again....
This is a closer look for the area..
Again, many thanks your help
