AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Receiver Recommendation For 9.1 Setup
post #1 of 12
Hi,
I have already bought 9.1 speakers for home theatre with intention to use the additional 2 speakers for either front height or front width.
These are atlantic technology 2200's with dipoles/bipoles for rears and sides and monopole for all the rest.
What receiver or receiver plus amplifier setup is recommended while keeping the budget below 1500 USD.
Hussain
post #2 of 12
anyone?
post #3 of 12
The Yamaha RX-a3010 receiver which was last years model is still available through Amazon and will match your budget. It can power 9 speakers by itself and has amp outputs for Front Presence (which I suggest) and rear presence. I am running this unit with all 9 channels powered by ATI AT2000 series amps (because I allready had the amps from my previous setup), but in the wifes audio room which also has a yamaha RX-A3010 she does run 7 channels with front presence without issue.
post #4 of 12
Denon's 4311CI (few years old) is 9.2 and the new X4000 is 7.2 but can be expanded to 9.2 by adding a 2CH amp or another AVR; either of which can be had under your budget.
post #5 of 12
See if your local Costco has the Pioneer 1522. For $599 you can't beat it.
post #6 of 12
Are there any 7.1 receivers which can be expanded to 9.1. I particularly like the idea of having a separate amplifier for front 3 speakers
post #7 of 12
Never heard of one. Just get a 9.1 avr that has pre outs, that way you can run a seperate power amp.
post #8 of 12
Read post #4 again. wink.gif There's also the Onkyo 818 as well.
post #9 of 12
Compare prices versus features (I did), then call your local Costco to find out which nearby store has the Pioneer SC 1522k in stock for $599, drive there and get it. I did. I'm very happy.
post #10 of 12
sadly i can't as i don't intend to use it in usa and this one only works on 110 volt, right?
post #11 of 12
Probably should have mentioned this up front!
post #12 of 12
