AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Pioneer kuro pdp5080 plasma problem
post #1 of 10
I have a pioneer kuro pdp5080 plasma and I'm using the input 1 and when I'm watching tv the input 1 menu in the top right corner will show up for like 4 seconds and then go away! I tried to reset the tv by plugging it out but that doesn't work! Any ideas or help please? Thanks
Gear mentioned in this thread:
post #2 of 10
It is normal for the input indicator to appear when the source is first selected, and it should disappear after some time. Almost every TV I has worked one does this. I don't understand the fault? Does it appear randomly during use?
post #3 of 10
It shows up randomly when I'm watching tv!
post #4 of 10
Ah. Now, if you were to press a button on the TV itself, what button would do the same function -- or is there not one? For example, if INPUT makes that show up, then I would suspect the INPUT button has become intermittent. In addition, try isolating the remote control by removing the batteries while watching normal TV.
post #5 of 10
When I push input 1 on the remote it shows up! If I take the batteries out it still shows up, I even changed the s video cable so I don't know what it would be !
post #6 of 10
Can you make sure INPUT on the TV does not do the same?
Check the S-Video cable is seated fully on both ends, perhaps it is intermittent and causing the issue.
Try other sources too.
post #7 of 10
I only have 1 s video input in my tv and my satellite receiver only has the red white and yellow and a video, And it will show up and then be gone for like 5 minutes and then show up again!
post #8 of 10
Any chance you could try other inputs -- just so they can be ruled out? Does it have DVI/HDMI for example?
post #9 of 10
I changed it to red white and yellow and now it's good so what would make it only do that on the s video then?
post #10 of 10
I am thinking that perhaps some setting is wrong for that input? Have you tried a factory reset -- beware if calibrated etc.
