AVS › AVS Forum › HDTV › HDTV Technical › Audio issue with HDMI
post #1 of 4
Hello -
I have a SONY Bravia and am having difficulty getting audio when using HDMI output. I can get video just fine from my Laptop - just no audio. Any suggestions? Thank you
post #2 of 4
Are you sure that your laptop output is HDMI (and not DVI) ?? DVI has no audio.
post #3 of 4
Thanks -
It definitely has the hdmi output... does the DVI output look any different than the hdmi? Is there a way to tell if I have DVI vs. hdmi?
thanks
post #4 of 4
Try going into the control panel on the laptop and clicking SOUND. See what the setting is. Try changing it to HDMI.
  Back to Forum: HDTV Technical
