AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › TCP60ST60 issue with PS3
post #1 of 4
First off, sorry if I posted this in the wrong place ...
I recently purchased a TCP60ST60 and hooked it up with an Onkyo TX-NR717 along with my PS3 slim and DirecTV HD DVR. For the past few weeks, everything has worked flawlessly. Today, my PS3 would not display on the screen. First thing I did was to try to reset the PS3 to Safe Mode with no success. The, I hooked up the PS3 directly to the ST60 (bypassing the Onkyo receiver) with no luck. I even swapped out the Hard Drive in the PS3 - still no display. Next thing I did was to hook up the PS3 to a different TV and everything worked great. So, I narrowed my problem down to the TV and the receiver. Not wanting to believe that the problem was with the TV, I updated the firmware on the Onkyo receiver - still no display. I have directly connected the PS3 to all three HDMI inputs on the TV with no luck. So, now what? Any suggestions ... ?
Thanks in advance,
drew
post #2 of 4
UPDATE
I left my PS3 unplugged all night. This morning, I plugged it in and turned everything on and it worked fine. Some observations that may be relevant:
1. Yesterday, when I turned the TV and receiver on with the PS3 OFF, the TV displayed a black screen with the "no input detected" screen intermittently displayed
2. Yesterday, when I turned the PS3 ON, the screen would flash blue then go back to black. The display on the Onkyo receiver would indicate that a signal was present, but there was never any sound or picture.
3. Today, after plugging the PS3 in, but with it still in OFF, the TV displayed a blue screen
4. Today, after turning on the PS3, it worked like normal.
Hopefully, this is only a glitch and won't happen again.
drew
post #3 of 4
Originally Posted by booger8 View Post
UPDATE
drew
Glad you got it working again, it is odd that it did that, hopefully never happens again.wink.gif
post #4 of 4
My onkyo is sometimes wonky switching sources, my HT 360 blew 3 HDMI boards, after the second replacement board they sent me a 460 that has held up, but once every few months it will just put a blue screen....unplug everything for a bit and all is good for awhile till the next time.
I loved my old onkyo that was pre HDMI....I used it for sound and thats it....now running all my video sources through it, I doubt I will go onkyo again.
