AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › Panasonic DMR-ES35V > dirty VHS head > cleaning ?
post #1 of 2
There must be a specialist in this forum who solved that problem already. The VHS-Cassettes must have smeared dirt on the "reading head" - the image quality is less than poor ! How can I clean that device ? Thanks a lot for your answer in advance !
post #2 of 2
Have you tried using a head cleaning tape? They may be hard to find, but a wet head cleaning tape-they come with a bottle of cleaning solution that you place a few drops in an opening, and then place in the vcr and playback for a minute.
Though your description of the image quality sounds like it may be beyond a simple remedy like this, but it's worth a try. Perhaps you could find a local tv/electronics repair shop and call and ask if they still service vcrs.
  Back to Forum: DVD Recorders (Standard Def)
