AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › projector - pc setup ?
post #1 of 2
hi,
i'm new on here & from the uk so be gentle......
i have just purchased a benq w1070 & am getting 4 sets of 3d glasses in the next week or so.
what i am wanting to know is what do i need to run 3d movies from my pc , it has a q6600 running at 3ghz ive had it to 3.2 but backed it off a bit.4gb ram & a 1gb gtx460 graphics card from this i have a 1.4 hdmi cable to my projector.
all the movies will be on my h/d, so will i just need power dvd 11 or will i need nvidia 3dtv .
i'm a bit lost at the moment with how it works thru a pc.
also there seems to be a lot of pc games that will run in 3d what also do i need to do.
thanks.
also all the different 3d types is confusing . i will only be using my pc as i dont have a ps3 or blue-ray player so will they all play from my pc.
thanks again.
post #2 of 2
Might ask in the Benq 1070 thread, http://www.avsforum.com/t/1435626/benq-w1070-dlp-full-hd-3d-ready-with-lens-shift-for-1000 or in the htpc sections on the forum, http://www.avsforum.com/f/26/home-theater-computers. Check the faq written here, http://www.avsforum.com/t/1240499/faq-for-the-3d-htpc
