AVS › AVS Forum › Home Entertainment & Theater Builder › Theater Room Items & Accessories › Component video splitter 1 tv @ 1080p and one @ 720p?
post #1 of 6
Hello,
I hope this is OK topic for this forum. If not please suggest which might be better.
My goal: Keep all my gear in a single room while being able to watch it on multiple TVs with varying resolution.
I know there is a BIG problem doing this with HDMI but I'm thinking I might be able to split HD Component to signal to accomplish this. I have 1 TV that is 1080p and one that is only 720p. I want to be able to split signal from my receiver going to both TVs without loosing resolution on either ( I want to be able to watch it @ 1080p on one TV while simultaneously watching it @ 720p on the other).
Is this possible by splitting the component signal? If not is it possible at all?
Nick
post #2 of 6
Originally Posted by nickpowers View Post
Hello,
Nick
Hi Nick:
If you're splitting the signal, both televisions need to be at the same resolution. It would work if both sets were 1080p displays.
post #3 of 6
Originally Posted by myoda View Post
Hi Nick:
I knew that was the case with HDMI but component video doesn't do a handshake does it?
post #4 of 6
most newer 720p native resolution TVs will render an incoming 1080p signal, just displaying it at the lower resolution. Check your owner's manual. If your 720 display won't recognize 1080p then you have no choice but to dial back your source resolution.
No handshaking with analog video so the lower resolution TV will have no effect on your source device or other display.
Edited by weaselfest - 5/23/13 at 3:47pm
post #5 of 6
Hello,
Nick
I am not 100% sure but I don't thin you can do 1080p over component.
The issues with using HDMI is only that of distance. An HDMI Active Matrix switch will let you view all your display devices at the same time with the same input as well as watch different inputs on different TVs at the same time.. i.e. Wife in the kitchen watching TV you in the other room watching BR player. or both watching TV or BRP. A 4x4 matrix give you 4 different inputs and 4 outputs in any combination simulations.
Remember with analog you will need 5 cables 3 video and 2 audio.
post #6 of 6
I have a similar setup to what you described. One Roku outputting over component to a powered component splitter, which is then connected to one 720p display and one 1080p display. Sadly I can never get the 1080p resolution to stick. It always resorts back to 720p. I'm not sure why as it's an analog signal. I'll play around with it again tonight.
