AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › LCD Flat Panel Great Found Deals! › VIZIO E701i-A3 70-inch $1578
post #1 of 12
VIZIO E701i-A3 70-inch 1080p 120Hz Razor LED Smart HDTV ($1598, $1578 w/Prime) @ amazon
Normally $1699, hasn't been at this price for a while. I've been waiting for a price drop, it dropped $100 today.
Edited by jkjkll - 8/28/13 at 1:03am
post #2 of 12
Best Buy also has it for 1599 if you just want to pick it up at a b&m.
post #3 of 12
Y'all think now is a good time to buy this unit? Any idea if the price will drop within the next month?
post #4 of 12
Best Buy now price matches Amazon.
post #5 of 12
Except you gotta pay tax at best buy, unlike Amazon.
post #6 of 12
Picked this up at Costco yesterday for $1579 (plus 2% cash back with my costco AmEx card). It's replacing a 50 inch LG plasma. The other set I was considering was the Sharp 657U (for 20% more money). I liked the LG but it had big glare issues (the Vizio has a relatively matte-like screen while the LG is a mirror). Plus, due to some remodeling work, our great room can now handle a 70 inch set. Picture is great so far, although there is a relatively narrow sweet spot for viewing. I notice washout if I get more than about 25-30 degrees off center.
post #7 of 12
Do wall mount screws come with the TV?
post #8 of 12
There are four cosmetic screws that fill the mounting holes. Based on the number of turns it took to remove them, I would never consider using them to mount the TV (way too short). Just go to Home Depot or Lowes and buy four M6 x 20MM bolts for a couple of dollars. You very likely will also want to pick up some washers for the bolts because the back of the set isn't perfectly flat and I needed to use the washers to stand the mounting bracket off from the back of the set. This might vary depending on the type of mount you're using.
post #9 of 12
Thanks, got it mounted!
post #10 of 12
HI everyone,
I am a noob at this so sorry if I have dumb questions....
I just picked this TV up and mounts and every cable under the sun...also added the Vizio 5.1 soundbar with wireless rear speakers via subwoofer.
I am taking this week to do all drilling, carving and snaking through walls and hope to have a great end result.
My question is regarding the Vizio Costar which I currently use. It works great with my Toshiba(52in) but now that I am setting up the TV that has built in Apps....I am a little worried about any issues (multiple seem to be duplicate remotes, Interfaces (which one to use).
Should I not use wireless on the TV and dedicate the Costar or vice versa?
I know...alot....but if someone out there has the same setup, maybe I can get some advise...
Jaime
post #11 of 12
By the way....Loving the info exchange on the forums here....Learning much.:)
post #12 of 12
Originally Posted by jaimecruz View Post
By the way....Loving the info exchange on the forums here....Learning much.smile.gif
Welcome Jaime. AVS is the best place I know of for TV info. And, if there is a more active forum for consumer electronics I haven't ran across it yet.
