AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Audio playback issues with Denon 1712 receiver
post #1 of 6
Hey guys. Long time reader & now a first time poster.
I have recently hooked up my new home theater setup (and have been running it for a few months now). But I have come across a few issues, nothing major but annoying, mostly with my receiver & audio playback.
First off, what I have going:
Receiver: Denon 1712 7.1
Speakers: Pioneer SP-B21-LA (by Andrew Jones), two front & two rear
Center: Pioneer SP-C22
Sub: Acoustech PL-200
HTPC, PS3 & HD PVR & connected via HDMI. I also have a pair of Yahama outdoor speakers connected via the Zone 2 option.
When everything was setup, I went through the Audyssey MultiEQ XT feature to dial in all the speakers & sub.
Now, here are my issues:
First: My HTPC plays in 5.1 when I'm watching media thorugh XBMC, but will not do it anywhere else (when I'm watching YouTube, listening to iTunes or watching media through Media Player Classic). I went through the setup on the audio manager on the HTPC & everything seems how it should be. I feel like I am missing something simple here? Or maybe not..
Second: When I have my iPod hooked up via an RCA auxiliary cord, and the receiver is on the appropriate 'Dock' input...I don't get 5.1 either. I only get sound from the front two speakers. I have gone through all the options & menu's on the receiver &, again, everything seems to be as it should. I'm assuming I can play the iPod in 5.1 & am just missing something..
Thanks for any help/direction you guys can give me..
Gear mentioned in this thread:
post #2 of 6
Not sure, but it seems to me you are feeding the receiver 2ch (stereo) material, and that's what it will play back. If you want 5.1 with these sources, you can engage something like Dolby Pro Logic II. It's not true 5.1, but it will simulate surround sound best it can.
post #3 of 6
YouTube, iTunes and your iPod are all two channel sources. You need to change the sound mode on your receiver to something like Multi CH Stereo then you'll get sound thru all of your speakers.
Page 27 of your manual discusses how you can press the Movie or Music button on the remote several times and change to different sound modes. Press the button until you get to Multi Ch Stereo and you'll be fine.
post #4 of 6
Ahh...beautiful, that's what I was looking for! However, it doesn't stay on that setting when I change sources back & forth. I also don't have a page 27 in my manual, it only goes to Page 8 & is pretty basic.
So when I have my HTPC on the 'Multi CH Stereo', & switch to my PVR or iPod, then back to the HTPC...it has set itself back to the default output setting. So I have to hit the 'Music' button to get it back to 'Multi CH Stero'.
I'm assuming there's a trick to make this the default setting?
post #5 of 6
If you purchased the 1712 new it would have come with the 100 page Owner's manual on a CD. It is likely the Getting Started Guide you are referring to. If you don't have the CD, you can download the manual at Denon's Downloads website below ....
http://usa.denon.com/us/downloads/pages/instructionmanual.aspx
The AVR will remember the surround mode unless you are using a Quick Select button to select the source in which case you will need to re-memorize that Quick Select button.
Also note there is a dedicated thread for Denon AVR-XX12 Owner's at ...
http://www.avsforum.com/t/1334369/the-official-denon-avr-xx12-model-owners-thread/0_100
Review posts #3-6 in that thread for additional helpful information.
post #6 of 6
Ok thanks for the link. I will shift my questions to that board.
