AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Denon AVR 2313 video output question..
post #1 of 4
Hi folks..
I just wanted to ask a simple question about one of the video settings in my Denon AVR 2313. My projectors deinterlacer is pretty bad, the worst I have seen actually. When it deinterlaces to progressive, the image is jumpy, it actually jiggles from side to side lol so I was wondering if there was a particular setting in the video options specifically just for deinterlacing, or do I have to enable the upscaling function too? I am confused if this setting is either I/P scaler or video conversion...
Thanks in advance people.
post #2 of 4
i/p scaler (anything but off) + resolution matching the input's (576i in, 576p out)
The video convert is really about transcoding from one type of signal to another, like S-video to HDMI.
post #3 of 4
The "Video Conversion" setting defaults to ON and you'll generally want to leave it at that setting to allow the GUI overlay to display. You also may want to consider letting the source do the conversion. Also note for more helpful information, review posts #3-6 from the "2012 Denon AVR-XX13 Models" thread linked in my sig.
post #4 of 4
Brilliant thanks, my AVRs deinterlacer is bound to be better than the projectors smile.gif
Thanks again..
