AVS › AVS Forum › Audio › Speakers › Arx A1B Bookshelf Speaker Review with Audio Demonstration
post #1 of 12
Hey guys,
Lets try this again, I had problems finding music that wouldn't get pulled from YouTube but I was able to find a local artist to let me use one of his songs for the audio demonstration.
I recently picked up the Arx A1B bookshelf speakers and wanted to post a review.
I'm powering the Arx A1B set with a Harmon Kardon HK3490 stereo receiver, 120 watts per channel, 12 gauge speaker wire with banana ends.
Pros:
Feel well built
Price point
Sound Amazing – Good highs all the way down to the lows
Cons:
Some would say the looks though I think they look fine
Planar tweeter is somewhat directional, you need a good listening position for crisp highs
Check out the video here
If you have any questions, please let me know, I'll do my best to answer any questions.
Final word: These are well worth the price tag! I'd buy them again in an instant!
post #2 of 12
Nice review and video. I, too, have these speakers for my private office. They sound great and are very affordable, imho.
post #3 of 12
Yes, they are great, they work perfect for my office.
post #4 of 12
How do they handle loud music? I like what I have read about these speakers so far, but I'd like to know what their dynamic range is like.
post #5 of 12
I've cranked these up pretty loud, no distortion that I can hear. Range of sound stays steady through higher volumes. The receiver Im using also isn't the best. I know some of the others on here would certainly have something better.
post #6 of 12
I think one would be hard pressed to find a better receiver for 2 channel listening for under $500 (see Audioholics review).............Sounds to me like this receiver is a good match for the A1b's, especially in a near field setting...........
post #7 of 12
I am certainly happy with the Harmon, I'm curious if they'd sound much different with something even better?
post #8 of 12
Imho, your power source is excellent. However, other things(DAC, File type, etc) might be the rate limiting factor, not the HK. This is just my $.02. Hope this helps.
post #9 of 12
I'm fairly new to some of the audio lingo, so I'm hoping to clear something up. DAC = Digital to analog converter right? Doesn't the HK have that within? It has digital coax in and optical inputs, or am I not understanding how it all fits together? As far as digital audio files, is FLAC the best?
post #10 of 12
I ripped all my CDs in AIFF (uncompressed), good for quality, compatibility, and metadata. Lossless compressed formats often have compatibility issues (running through various editing software), so I avoided all of them. The other option was wav, but I liked having artwork attached to the files.
What's the price on these speakers? I might like something like that for my zone 2 (bedroom) to use with Airplay. How would they compare with Polk TSI200 and RTI A3?
post #11 of 12
They run $300/pair from TheAudioInsider.com. I personally haven't heard either of those polks, I have some of the lower end polks for my home theater, those don't shake a stick to them but they were less price wise.
post #12 of 12
how do these compare to the HTD level 3 bookshelf speakers?
  Back to Forum: Speakers
