AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › Suggestion on High-End media streaming solution!!
post #1 of 5
Hello, here is my setup
Samsung 55" 3D LED TV
NAD T 187 Surround Sound Preamp Processor
NAD T 977 Seven Channel Power Amplifier
Paradigm Speakers (Full 5.1 setup)
Synology DiskStation 12-Bay NAS DS2413+ (48TB) loaded with all 3D ISOs and 1080p MKVs
Now, my question is, What is the best media streamer out there out of the box? please note that I have tried before to setup my own HTPC desktop but was too much complicated, so i need the best media streamer out there with high end specs and be able to handle all media files and high bit rate ISOs and FLACs to be used to both 3D Movies and Stereo Music.
post #2 of 5
i think POP corn hour A 400 would cut it...wide media support..HDD support..streaming ...go for it
post #3 of 5
I've read about it but never try it before!! If I decide to go for Popcorn, do you think its worth go for Popcorn Hour C-300? or A400 is enough?
post #4 of 5
any suggestions please?
post #5 of 5
If you want to play 3D movies then you go with Mede8er. If you don't care about 3D movies I would suggest Dune. Popcorn hour is another option.
