AVS › AVS Forum › Industry Area › HDMI Q&A - The One Connector World › HDMI Splitters - Do they work?
HDMI Splitters - Do they work? - Page 2
post #31 of 35
Thanks for all the links / information. The TV is late 2005, so it just was not as popular. The TV in the basement is from about 2008. I'll start reading about this now since I think it am going to do it.
post #32 of 35
I found one on Amazon: Kinivo 501BN Premium 5 port High speed HDMI switch with IR wireless remote and AC Power adapter - supports 3D, 1080p
It is automatic, comes with a remote, and has a button as well. We are installing it this weekend and will report how (not well it works.
It is about $60,00, but we are prime members and it was $40.00.
post #33 of 35
Corey you can get the same thing at Monoprice for 25 bucks and I would tend to go with them for customer service if need.
http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10110&cs_id=1011002&p_id=8203&seq=1&format=1#largeimage
post #34 of 35
Ah, even better! Thank you!
Well, we tried it and it does not automatically change, but it does have that remote. Maybe it will change once it "charges" up. I am hoping that it will be able to "teach" the remote.
Unfortunately, the Logitech One (I think that is the one we have up there) is on its last leg in communicaing with the TV. I am going to try to maybe see if that is supported. Otherwise maybe the Harmony Touch. So far, not impressed with the Ultmate.
post #35 of 35
‘Maybe it will change once it "charges" up’ – wishful thinking, many Source devices fail to signal when they go In/Out of Standby so can defeat the Auto Source selection your Switch has on offer.
Ideally you want a Switch with a discrete (unique) IR code for each button.
Joe
