AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Official ZT60 Owners Thread
Official ZT60 Owners Thread - Page 59
post #1741 of 11442
Originally Posted by Speakerphile View Post
Any single person using a single dealer is not statistically significant. If anything, it would point to a problem related to a bad batch of parts. It would need to be accompanied by a much larger sample size of similar issues experienced by people that have received their products at varied times and locations. This would also elevate return rates, at least slightly. I find it far more likely they have inconsistent quality levels in the fans or fan controllers that they use. I agree that you having 3 bad apples is significant, but you are making assumptions many levels deeper than your data supports. Also, free basic delivery should be included with any TV in MHT.
You are right, that is the reason I also mentioned my final mid-August exchange. By that time, the entire current inventory will be gone, and a new batch is received at the warehouse. Last time they checked, they had about 20 units left in the warehouse, and with current sale price, they should be gone faster. So hopefully, a month from now, the new batch should be here. If the new exchange is also having problems at that time, then my assumption that people have different hearing/room structure will have more bases and more data to back it up. Unfortunately, we have to wait a month and see the result.
EDIT: yes, the normal warehouse delivery is free, but if I knew the GS delivery only costs a little more, I would have gone for it instead of standing there and watching their power driver stripping the screws.
Edited by Lost! - 7/14/13 at 9:30am
post #1742 of 11442
As far a PQ, this TV is quite superior to my Elite 60 it replaces. However I have seen weird things; subtitles get "broken" during fast scenes when the camera moves rapidly from left to right or vice-versa. I also see some "ghost" or whatever the name is, around some images, mostly around a subject. It looks like when the Predator is walking on its invisible mode. I have been watching movies on THX mode and also on Cinema mode with settings I found on this thread.
Do you guys think this subtitle and ghost things are an issue?
Thank you.
post #1743 of 11442
Did you purchase from an MDC, or an MHT? It should be interesting to see what happens. Hopefully this is something that Panasonic has addressed going forward. It's a shame to let even a small issue like this fester and mar the image of an otherwise great product.
post #1744 of 11442
I have purchased from MHT. Yes, I cannot agree more. This TV is great in all aspects, but with a tiny problem. We are actually enjoying the picture a lot. We still are amazed by the depth that we can see in normal Blu-ray disks, and even in animations like Madagascar 3 we just watched last night. The shadow details, depth, and bigger screen actually make ordinary 2D pictures almost 3D in this panel.
post #1745 of 11442
YIKES! Your composure about it is amazing. Although, I'm not sure why GS would be less likely to strip the screws. I was told the warehouse guys are also BB employees.
I decided to pick mine up at the store so I could get it a week earlier. I guess I won't be using a power driver...
Any tips from those who have set the TV up themselves? I need to attach the stand and set it on a built-in entertainment center. Do I need to avoid laying it flat and always keep it vertical? I have my wife to help me. She is strong like bull.
post #1746 of 11442
You should be fine just by following the directions to a "T" and using a manual screwdriver that is the correct size.
post #1747 of 11442
Thank you.
Turn off motion smoothing in the PQ settings if you haven't already.
Laying on its side on a soft surface should pose no problem...it will make it much easier to install the base if you do.
post #1748 of 11442
Thanks Speakerphile. By the way, I visited two different BBs in my area before buying. The Magnolia blue shirts in both were knowledgeable and helpful. If it matters to you.
Anyone know if the bottom of the stand has felt or something soft? Else I'll need to add that. I'll need to slide the TV back on my entertainment center once the cables are run. Don't want to scratch the built-in. Thanks.
post #1749 of 11442
MHT told me the installers should not use power drivers on the TVs. He said he had a customer who returned $7K Elite because of this fact. He told me GS installers use manual screw drivers.
The stand is fairly easy to attach. I've watched 3 sets assembled in front of me. The V shape piece is already attached to the base, so you only have to put the bracket on top of it and fasten 4 screws. Then you only need to put the plastic bracket on top, and use the small screw. After that you definitely need two people to rotate and hold the TV to attach the pedestal.
Now, I have seen two different methods by the 3 different teams smile.gif One of them completely rotated the TV, 180 degrees, and attached the pedestal from the TOP of rotated panel. That way, No body needed to hold the pedestal in the place, and I think it is safer for getting an even install. One other team, rotated the TV 90 degrees, and attached the pedestal from the right. This way, they needed 3 people, one to hold the TV, one to hold the pedestal, and one to tighten the screws. It is up to you which method you want to use, but the first seems more convenient. By the way, get a microfiber cloth ready, since after so many rotations the screen is going to have a lot of fingerprints on it that you have to patiently clean with the cloth.
post #1750 of 11442
That is great to hear. I know there is a lot of work going on right now to make sure that training is major priority in MHT locations.
Regarding the stand, I don't know for sure, but would assume there are at least little rubber feet on the bottom.
post #1751 of 11442
^^^ thanks for the details Lost!
post #1752 of 11442
Did you purchase from an MDC, or an MHT?.
Is there a difference between MDC and MHT when it comes to purchasing an item? Is one better than the other?
R
post #1753 of 11442
R
No, but the inventory shipments are separate, which was the context under which that question was asked.
FWIW. The MDC sales teams are on commission though. Some people feel that that gives them increased incentive to take care of their customers. MHT sales teams are shared with Best Buy home theater and are not on commission.
post #1754 of 11442
Thank you.
No problem with subtitles with my ZT60.
post #1755 of 11442
What are the "base settings" for those who have calibrated their displays? I will be using Chromapure and an i1 Pro/Display 3 combo (and hopefully control cal).
From what I have read thus far, Gamma = 2.4 and Panel Brightness = Mid. What mode(s) are getting the best results? What settings do you suggest I turn off?
Most critical viewing is done from blu ray/.mkv's played thru a PS3/HTPC (MPC-HC, madVr) connected to a Denon AVR 1713.
Thank you,
post #1756 of 11442
Bought my 65ZT60 June 4, became Silver Premiere member after that, went to BB today and offered either to return or get a price matching. Manager did the price match without problems. Great Customer Service BB !!!
post #1757 of 11442
It seems to be working. Thanks for the input.
post #1758 of 11442
At what price is BB offering now? Online is $4099, same price I paid a week ago.
post #1759 of 11442
Think it dropped to 3199 for the week.
EDIT: in store only, online prices won't update to reflect. I had to go to BB/MHT to get my price match. I called the store before hand and the verified the new prices. Online was still the old prices.
post #1760 of 11442
$3199 for the 65" ZT60. Ohh my is that a steep discount
For the new plasma. I feel I way over paid at $4099.
I thought maybe the price would drop $200 or $300 after awhile
but Not that much. Wow! Double Wow!
post #1761 of 11442
Thinking about paying BB a visit tomorrow!
post #1762 of 11442
The price at the best buy I went today had the zt65 priced at 3499....
post #1763 of 11442
They may have quickly realized that there are still so many people within the return period, and they cannot refund everyone.
post #1764 of 11442
Went to my MDC today. $3,199 was price for wed to sat. Today (sun) went up to 3,499. (Prices for 65zt60) Though my guy at MDC said he didn't know how long that price was going to be at. It was a non advertised drop.
post #1765 of 11442
$3199 is a steal of a deal for a ZT, even less than the f8500 (which I currently own). At the risk of looking really crazy, I must admit when the price dropped I went and exchanged my 8500 for a ZT. So it's back to Panny for me, part of my decision to go 8500 was the ZT's $4k+ price tag that I couldn't justify with the fan issue.... Now fan noise or no fan noise I couldnt say no to the ZT for $3199. I'll live with the fan noise! I'm glad I got to try the 8500 out and now I can say for myself that I prefer the ZT PQ and style.
post #1766 of 11442
Any price drop on the 60"?? Or just the the 65".
post #1767 of 11442
So, when do you get the new unit? I am very interested to know if you will have fan noise again. My theory is those that experienced the fan noise, will always hear it, but I don't have enough data yet. Let us know. BTW, 8500 is a great set too and has its applications, but I agree that at the new price ZT is perfect.
post #1768 of 11442
post #1769 of 11442
Got about 10 hours on our 65" ZT60...replaced a 65" V10 (good ole trusty!)
What a difference! I plugged in the cnet calibration settings just so it was something other than stock. loving this thing!
post #1770 of 11442
oh and ours is #2449.
