AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Official ZT60 Owners Thread
Official ZT60 Owners Thread - Page 152
post #4531 of 11384
Originally Posted by mjodotcom View Post
Anyone else notice that the very last pixel line to the left on the screen has a slight purple tint to it? I caught it while running the break in slides. Thanks!
That's normal for plasma. you shouldn't see it watching normal media.
post #4532 of 11384
Got it - thanks a lot!
Also just noticed that I didn't turn the pixel orbiter off for the first 50 hours. I turned it off now and after playing with it it looks like it actually moves the whole picture around a little bit. For reference, when turned on does the image shift around on a certain time interval or something?
post #4533 of 11384
Originally Posted by elbobo19 View Post
Not sure how much buzz you are getting but I can tell you the buzz I am getting is not normal, during bright scenes it can be heard over dialogue at my normal volume(-33db on my receiver).
I went to a local best buy that had this tv and the buzz was maybe 1/4 what I am experiencing, I could barely hear it with my head right next to the tv.
My experience with buzzing is the room acoustics and mounting style can drastically change it. In my room, I could hear buzzing on similar minus -30ish (Denon receiver) volume levels. I also had loud fan noise (July build) and a purple halo so I actually exchanged the set. Next TV that arrived was also July build but had a quieter fan and no purple halo so that's good, however, the buzzing sounded very similar. This made me think it would be highly unlikely to get two equally "severely bad" buzzers so I started to experiment since this was the only remaining issue. I put a blanket behind my tv on the wall which is like 18" away (I have it on a stand) and this cut it down to the point you couldn't hear it anymore unless the volume was off and you tried to identify it. It was clear that the walls and geometry of the room was amplifying the sound.
My $0.02 on some other things you can try. Comparing how it sounds in best buy is very tough because of all the environmental (noise, room, etc) differences.
Edited by mjodotcom - 11/27/13 at 8:52pm
post #4534 of 11384
"It was clear that the walls and geometry of the room was amplifying the sound."
Very interesting comment. I think you are on to something with that observation.
post #4535 of 11384
I have DVE DVD, but I want to upgrade to a blu-ray calibration disc. It would be great if I can also use the disk to set up my 5.1 surround. I saw Disney WOW blu-ray being mentioned a few times here and on other forums, so unless there are better options, I am thinking about going with that.
Which blu-ray calibration disc do you recommend for this set?
post #4536 of 11384
Hey guys,
I just bought the P60ZT60 tonight and I am having it delivered in a week. I was curious if I need to break the tv in? If so could someone please tell me what I should do. I was looking at the Sony 4k but when I saw this tv I knew that this was the better set. Thank you for any help.
Clayton
post #4537 of 11384
Yes, but I don't know what it is. I don't own a Panasonic, but I understand that if you select FULL size mode, the Orbiter will be turned off and the source data stream will be mapped on the screen pixel by pixel which will be the optimum picture quality possible. How good that is will also depend on all the other settings and how they are adjusted.
post #4538 of 11384
If you want more than the Wow disk offers then go to spearsandmunsil.com. I have an audio calibration disk from aixrecords.com. It's title is AIX Records: Audio Calibration Disc, HD Music Sampler.
post #4539 of 11384
Originally Posted by vinnie97 View Post
What does that mean, a full month and a half? 1080 hours?eek.gif That won't lessen the susceptibility to IR/burn-in anymore than 300 hours will (the maximum you should bother breaking in).
are u sure???? nothing wrong with trying anything or everything to stop burn in lol......
post #4540 of 11384
I have a 65ZT # 085XX that also has a build date of July - delivered 11/8 - no pixel problem - minor fan noise - barely noticeable
post #4541 of 11384
Actually, even a month and a half of slides may not be enough. I recommend doing 7 months and by the time you're done you can just buy next year's model.
Edited by Terebi - 11/28/13 at 4:06am
post #4542 of 11384
Originally Posted by Edllguy View Post
"65" Zt60- A10912- Build August here in Canada. Just arrived not hooked up yet."
denaliman,
Can you let us know how the fan noise is. Congrats on your August ZT build unit. Cherish it.
I can report a very slight fan noise. I am not sure what others are hearing and how loud theirs is. I don't hear whistling, whining or a loud noise. I can definitely hear a slight fan running from 10 ft away. More like the sound of a computer fan running and I do notice it during quiet dialog, again because I know it is there.. However, I am really listening for the sound. My wife says she can't hear it unless she gets right up to the panel.. Maybe I am being picky and expecting the noise to be there. Personally I find the slight buzzing more annoying.. My 8 year old 50" PX500u Panny Plasma that I just took down was dead silent and no buzz at all.
post #4543 of 11384
FWIW...I checked my 65"VT50 for fan noise as well. I don't think the ZT I have is any worse than the VT. I sit further away from my VT and never really noticed it or thought it was an issue. Now that I am aware of the fan on the VT50 (geeze thanks guys!) I can hear it on mute or very slightly low volume scenes if I concentrate, but normal listening volume it is a non-issue. Although the "tone" of the VT fan is not as low drone as the ZT. Given that, I am guessing I got a better than average ZT.
post #4544 of 11384
Hey guys, as most of you know I'm taking delivery of my ZT on Saturday. Couple questions.
Its been cold lately and of course my ZT will be exposed to the frigid temperatures. How long will I have to let my ZT adjust to normal room temperatures before turning it on.
Also, I downloaded D-Nices break in slides for 2013 Panasonics. I'm questioning whether I downloaded the correct ones. There are only 15 slides: Red, Blue, Green and the rest of various shades of gray/white. Is this correct?
A temperature gun, they are pretty cheap smile.gif Get one of those and you will know when it is time smile.gif If you are willing to break in your set, isn't your new toy worth it ?
An hour or two........you can feel it with your hand to get a sense when it is room temperature.
post #4545 of 11384
deleted
Edited by changboy - 12/29/13 at 9:26pm
post #4546 of 11384
Interestingly, I shot both the 65' Zt and 60" F8500 with my laser temperature gun. Front of panel top left Panny is 112F, bottom left 98F, center middle of panel 112F. top mid 102F, Top right 108F bottom right 98.5F- Ambient room temp 69.5F
F8500 top left 90F, bottom left 87F, center middle 87F, top mid 102F, Front right 94F bottom right 90.5F- ambient room temp 70F.
Panny is considerably hotter. Both on for 6 hours same content
post #4547 of 11384
Originally Posted by changboy View Post
My ferrari do a big noise maybe i should go at my dealer for a complete check-up.....tongue.gif
I don't follow...what is your point??
post #4548 of 11384
deleted
post #4549 of 11384
deleted
Edited by changboy - 12/29/13 at 9:27pm
post #4550 of 11384
My point is people never complain coz ther ferrari do noise, that was for kidding and btw i down own a ferrari....biggrin.gif
Gotcha, no harm.
post #4551 of 11384
Iam curious to know if the back top of the samsung is close like the panasonic coz when i unpack my box the first time and put my new screen on the table i were surprise saw most of the back of the ZT was close, just hole where the fan but the good its the dirty will go less inside this panel.
The back of the Samsung is just as close. Panny panel thickness is 1.9" and the Samsung is 2.1". The Samsung has a lot more open holes across the top for cooling, heat exhaust. Panny has approx 54 sq.In of open cooling vents vs Samsung 204 sq.in. almost 4 times open cooling vents that ZT.. Samsung also has no fans so it doesn't have the potential pull in excess dust from the incoming air flow like the Pannys..
post #4552 of 11384
deleted
post #4553 of 11384
Do you own both tv , or you working in electronic store ?
LOL you would think so. Yes..I own both plus another 65" VT50 a 42" Hitachi and a 50" older Panasonic PX500u.
post #4554 of 11384
deleted
post #4555 of 11384
Wow. Are you opening a museum?
post #4556 of 11384
deleted
post #4557 of 11384
Hehehehe, omg you have more screen then me i just have 3 plasma hehehe, so witch one you prefer, pana or sammy ?
Jury has not decided between the Zt60 or exchange for another f8500 leaning towards keeping the ZT
post #4558 of 11384
Ha Ha...The Hitachi is in the one of the bedrooms and still has an awesome picture especially for watching Formula One ,racing and other sports and it is not even Full 1080P. Quiet as a mouse, no buzz and SD broadcasts look great.
post #4559 of 11384
deleted
Edited by changboy - 12/29/13 at 9:28pm
post #4560 of 11384
deleted
