AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Ideas / Help sound proofing A/V rack ???
post #1 of 16
I'm in process of designing my theater and one question I have is what do people do to minimize the sound from AV rack ?
I'm going to have a HTPC and server in my rack - and also a few amps and such. It's all got fans that make noise.
My theater is set to be 32x24' - I want to keep the equipment and rack in the room.
post #2 of 16
Very good question!!!!
I'd like some input on this as well
post #3 of 16
That room space makes for a huge theater.
post #4 of 16
I'm putting a solid door over the rack (in a closet with the front looking into the theater through the soundproof wall) this time around. It will probably be made to look like the wall treatment (fabric over acoustical panels). The closet will be lined with Linacoustic duct liner board.
In my last theater I used the smoked plexiglas doors that Middle Atllantic makes for the Slim 5 racks. That worked well, but that theater had no soundproofing, so the noise floor was significantly higher than what I expect in the new one.
post #5 of 16
I'm planing four chairs in front row, couch and two chairs second, and about 8 folding seats in third row. Then a full bar area in back with a counter facing the screen against back of third row. Also a false screen wall.
post #6 of 16
I'd like to keep my rack in the Theater. Possible in front (fake screen wall built in)
Or sides ...
I'm just looking for good way to make it silent
post #7 of 16
Or sides ...
I would definitely make sure your rack has a door if your placing it in the front. All the lights on the little gadgets can get annoying when trying to watch a movie in a dark room
post #8 of 16
You should PM BigmouthinDC, I am certain he can advise you properly. The face of my rack will be in the room and the body will be in its own room. We sound proofed the rack room so I am assuming this will decrease the amount of unwanted sound in the theater room. From what I was told, some equipment fans can be a bit noisy, but in my case I more than likely will not use my rack fans at all.
post #9 of 16
Or sides ...
For this reason I thought the side or rear side made sense. Also closer to projector and easier for future proofing. I'm going to have a PC in back of theater too. If like to make it quiet and rack mount it. It doesn't have to be built into the room.
I'd actually prefer it to be not built in. I just don't want rack noise polluting my theater
post #10 of 16
Thanks for advice!
My issue is I don't have a room really I can use as equipment room. Unless I steal space from wife closet lol. She's not cool with that.
It's better to keep it in the room in my case.
post #11 of 16
If I were to try to put a rack inside the room, I would put sides on the rack, and door front and back. I would probably use some of the automotive sound deadening materials (VibraBlock, etc) on the inside of the sheet metal sides and doors to deaden them. Your problem will be providing adequate ventilation. Maybe some variation on a dead vent for the air intake and exit points from the rack.
post #12 of 16
I would vote for a little closet built within the room, specially for the AV rack. Make sure it is properly vented.
Also, with the full bar in the back, I assume you will have a fridge or a mini fridge? Be aware that those guys also pump out some serious noise, might want to reconsider and/opr think about how to minimize the sounds coming from it.
post #13 of 16
I'm debating the fridge. Great points and I'll look to sound proof for sure.
I might have a draw curtain in the back to seperate the bar area from the theater. I could close it to help when it's just me smile.gif.
post #14 of 16
Great advice ... Much appreciated
post #15 of 16
I've had luck using these on the pellet stove and some of our DJ road racks with very good results
http://www.acoustic-material.com/HTML/noise-damping.html
You might try attaching some of these sheets to the inside of the rack to control fan noise. For me, I like showing off my components but then again I'm a Wedding DJ and I like the look of having them exposed.
post #16 of 16
I do like the look of showing off the equipment.
I'm playing with design to place it behind the first two rows and facing sideways towards center room.
