AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › Xbox Area › The Official Kinect Thread for Xbox One
The Official Kinect Thread for Xbox One - Page 7
post #181 of 354
No official word. I called Microsoft because i was considering purchasing an xbox one but my equipment rack is 23' from the screen. All they said is nothing is available and that the previous extension cables wouldn't work with the new kinnect. Once they sort out an extender cable or wireless solution i'll be on board for the xbox one.
post #182 of 354
I'd be surprised if they ever have a wireless solution. Since it would introduce more latency plus the data rate is up to 2Gb/s. I know there are solutions that can handle the high speeds but I would think any extra latency would not be wanted when using Kinect.
post #183 of 354
so crowded in the main thread so thought it'd be easier to find the Xbox Fitness video over here...
post #184 of 354
http://www.ign.com/videos/2013/11/06/d4-is-xbox-ones-weirdest-game-and-thats-awesome
Very interesting looking game, and the Kinect use is cool. I knew it could detect your hand opening and closing, but it can also detect holding up two fingers! Looks bizarre as hell, but could be a cool use of the new Kinect.
post #185 of 354
Major Nelson's demo of the QR code reader! no more typing long codes!
post #186 of 354
the TV mount will be available even before the new Kinect is available!
http://www.gamestop.com/xbox-one/accessories/xbox-one-kinect-tv-mount-kit/112623
post #187 of 354
This is maddening that we're nearly 2 weeks from launch and Microsoft doesn't have an extension cable solution?! Forgive me for the noobish question, but what is unique about USB 3.0? Am I correct in my assumption that is the true hang-up?
post #188 of 354
What's unique is their connector. I wouldn't expect an extension cable to materialize by launch or from MS at all. My guess is that some 3rd party will manage to license the connector and offer a cable.
post #189 of 354
Any word on a maximum distance that you can sit from the Kinect?
post #190 of 354
I haven't heard any. They've been mostly concerned with reassuring people that they can use Kinect in small rooms, which was a problem with the 360 version. The assumption would be that you could always move closer.
post #191 of 354
I had just asked this in another Kinect thread. W/ the 360, the Kinect didn't work well for me, as it wouldn't pick me up very well while sitting on my couch 15' from the screen. Though it was OK for some games where you had to stand and/or jump around in front of the screen, I'm really looking forward to sitting on my couch and getting into some Battlefield while using the head-tracking features of the Kinect.
post #192 of 354
the PDP Kinect mount is out in stores apparently... I don't know if they are an official Xbox One vendor this time around. They were for the 360 and the PDP Kinect mount for the 360 Kinect was fabulous. so much so that there were plenty of fake PDP mounts (which performed terribly; I had to return a fake back to Amazon and got a real one at Best Buy).
post #193 of 354
For those looking for dimensions of the console and Kinect 2.0:
Here you go. Let the home entertainment designing begin!
Xbox One dimensions (LxWxH): 13.1" x 10.8" x 3.1"
Kinect 2.0 dimensions (LxWxH): 9.8" x 2.6" x 2.63"
Now that I have the dimensions I can see that I can't put them side by side in my TV unit like I wanted. Any reason I couldn't put the kinect on top of the console?
post #194 of 354
Other than blocking cooling vents I can't think of any.
post #195 of 354
Would blocking that much of the cooling vent make a difference?
post #196 of 354
Unknown. The massive cooling fan is located at the front of the top vent. I don't know what direction it blows in. If it's outward it probably doesn't matter at all. Seems more likely to be inward.
post #197 of 354
I'm going to place my Kinect on top of my center channel, the XB1 will go in its own alcove where my HTPC currently resides.
post #198 of 354
I have a similar problem as to where to place my Kinect 2; I'd like to put it where my center channel is currently located (just below the screen of my TV on a TV-stand-type A/V equipment cabinet). I'm keeping my 360 and I want to keep its Kinect hooked up, mostly for games with voice commands like Skyrim, Mass Effect 3 and Rocksmith 2014, so I don't so much care about its camera. It's currently mounted on top of my television; I suppose that I can get a Kinect 2 TV-top mounting and push the 360 Kinect to the side.
My center channel doesn't have a flat surface on which to place the Kinect and even if it did I'd worry a bit about the sound from it interfering with the operation of the Kinect.
post #199 of 354
Lucky, I can't find it anywhere!
post #200 of 354
Amazon says that it releases on December 4th and Gamestop says November 20th.
post #201 of 354
For some reason Gamestop gets some of their things early. I got the Nyko Charging Base for the XBOne from Gamestop. I received it a week ago from them while everyone else is showing a release date of the 22nd.
post #202 of 354
post #203 of 354
IGN's how to set up the Kinect:
post #204 of 354
Great vids, thanks!
post #205 of 354
post #206 of 354
Originally Posted by spid View Post
List of Kinect commands at launch.
http://support.xbox.com/en-US/xbox-one/kinect/voice-commands
apparently there are more commands than listed at the official support page:
http://www.pocket-lint.com/news/125190-xbox-one-voice-commands-list-how-to-control-your-new-console
Xbox select - You can also interact with your Xbox One console by saying “Xbox, Select.” When you say “Xbox, Select,” some features appear in green text. This lets you say just that word. For example, if you say “Xbox, Select” while you’re in Xbox Video, you can just say “Movies Stores.” Shows voice command options for everything on the screen that is supported, highlighting relevant commands
"Xbox On"
“Xbox Démarrez”
(French)
“Xbox An” (German)
Turn on your Xbox One console (works only when Instant-On power mode is enabled). Wakes up Xbox One, can turn on television and cable/satellite set-top box
“Xbox, turn off”
Turn off your Xbox One console. Puts Xbox One to sleep/off, can turn off television and cable/satellite set-top box. You'll then have to confirm you want to turn it off with a "yes"
“Xbox, go home” or "Show my stuff"
Return to the Home screen. Returns to Home. This is the command you'll probably use the most.
"Xbox, go to "
Open and go to a particular application
(for example, Xbox Music or Xbox Video). Launches specific games, TV shows, apps, notifications and sections of the dash. This is a hugely important command, you'll use it a lot.
"Xbox, go back"
Go back to the previous screen. Returns to previous screen or menu option.
"Xbox, cancel"
Cancel the current action
Xbox pause/Xbox play - Pauses gameplay or resumes gameplay, meaning no more scrabbling for buttons when the phone rings
"Xbox, snap "
Snap a particular application. Launches activity in Snap mode. This is great fun and works well.
"Xbox, unsnap"
Unsnap a snapped application. Unsnaps activity in Snap mode.
"Xbox, switch"
Switch focus between snapped view and main view. Switches focus of the activities in Snap mode and Fill mode.
"Xbox, Bing "
Search using Bing. Launches Bing, then searches for the game, movie, TV show, game add-on or app using conversational voice. We've found it to be a bit hit and miss.
"browse to [website]" - Browses to a specific website when already in Internet Explorer.
"Xbox, show menu"
View the context menu. In full screen: shows menu for whatever is on the screen. At Home: shows menu for whatever is in the current window.
"Xbox, change view"
Change view (same as pressing the View button)
"Xbox, help"
Display the on-screen Help. Shows help menu with available options
Note When you do a Bing search, wait for the search box to display before telling the console what to search for.
Xbox, Skype
Bring up a list of your contacts
“Xbox, Skype ”
View the contact details of your Skype contact. Launches Skype call to a person from your Skype favourites list on your Xbox One
“Xbox, call ”
Start a video call using Skype. Launches Skype call to a person from your Skype favourites list on your Xbox One
Xbox, answer
Answer a video call. Answers incoming Skype call
Xbox, answer without video
Answer a voice call. Answers incoming Skype call
“Xbox, hang up”
Hang up or end a call. Ends Skype call.
“Xbox, send a message”
Send an Xbox Live message to a friend. Sends message to your Xbox Live friends.
“Xbox, sign in”
Go to the sign-in page to sign in to any profile
“Xbox, sign in as ”
Sign-in to a specific account (use the first name on the account)
“Xbox, sign out”
Sign out of the active profile. Signs in/out an Xbox Live member.
“Xbox, use a code”
Scan a QR code for a game or downloadable content. Triggers Kinect code scanning for QR codes for game downloads, etc.
“Xbox, notifications”
See your notification history
“Xbox, show notification”
See more details about a notification that appears. Shows on-screen notification(s).
“Xbox, close notification”
Dismiss a notification that is on the screen
“Xbox, answer”
Answer an incoming call when the notification appears
“Xbox, answer without video”
Answer an incoming call without video when the notification appears
Xbox play/stop/pause/fast forward/rewind/faster/ slower/skip forward/skip backward/next song/ previous song - Controls for media playback, works on both music and video
“Xbox, play”
Play video content. Launches video and music playback.
“Xbox, pause”
Pause video content
“Xbox, rewind”
Rewind to a previous point
“Xbox, fast forward”
Fast forward to a future point
“Xbox, faster”
Rewind or fast forward at a faster pace
“Xbox, slower”
Rewind or fast forward at a slower pace
“Xbox, skip backward”
Skip to the previous chapter
“Xbox, skip forward”
Skip to the next chapter
“Xbox, stop”
Stop playback of the content
“Xbox, play music”
Play music, starting with the last active playlist
“Xbox, pause music”
Pause the track
“Xbox, next song”
Skip forward to the next track of a playlist or album
“Xbox, previous song”
Skip backward to the previous track of a playlist or album
“Xbox, watch TV”
Watch live TV. Launches cable or satellite TV from set-top box. We've used this a lot, it works really well
“Xbox, show guide”
“Xbox, OneGuide”
Display the OneGuide. Launches OneGuide for cable or satellite TV subscribers. Less useful at the moment, as it's not coming to the UK until 2014
“Xbox, watch ”
Watch a specific channel
“Xbox, mute”
Mute your television. Controls volume of TV set or AV receiver, if enabled in the settings
“Xbox, unmute”
Unmute your television. Controls volume of TV set or AV receiver, if enabled in the settings
“Xbox, volume up”
Increase the television volume. Controls volume of TV set or AV receiver, if enabled in the settings
“Xbox, volume down”
Decrease the television volume. Controls volume of TV set or AV receiver, if enabled in the settings
“Xbox, invite ”
Invite a friend to a game or chat
Xbox start a party - Launches the Party app in Snap mode, although you can start the party at any time
“Xbox, record that”
Record a game clip or highlight. Records the previous 30 seconds of gameplay, which is a great trick for catching those.
Xbox - Shows menu of voice command options and begins listening for the next command
Stop listening - Stops Kinect from listening or cancels voice commands if Kinect is triggered during casual conversation
post #207 of 354
http://support.xbox.com/en-GB/xbox-one/kinect/common-gestures
Common Kinect navigation gestures on the Xbox One with the new Kinect 2.0.
post #208 of 354
Thanks. That should help with things.
post #209 of 354
Anyone had any luck with setting it on top of the center channel? I have projector screen- so can't use a tv clip- and if it needs to be centered I'm not sure what I can do besides set it on top of the center channel on the media cabinet or find a wall mount which I'd rather not do.
post #210 of 354
it has a standard camera mount underneath so you could use a tripod or similar device if you want. something with a screw mount. like a gorillapod.
Edited by onlysublime - 11/23/13 at 5:14pm
  Back to Forum: Xbox Area
