AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The "Official" Yamaha AVENTAGE RX-A1030, RX-A2030, RX-A3030 and CX-A5000/MX-A5000 Thread
The "Official" Yamaha AVENTAGE RX-A1030, RX-A2030, RX-A3030 and CX-A5000/MX-A5000 Thread - Page 37
post #1081 of 2277
fyi, a few posts back I mentioned a popping problem I was having when changing inputs etc. on the CX-A5000 Well, after some excellent assistance / troubleshooting with my dealer, including trying different processors, it turns out it's some sort of grounding problem, which I have fixed by replacing the RCA interconnects with XLR ones. Maybe the CX-A5000 is more sensitive wink.gif I will also get an electrician out to check the circuits!
Needless to say, I am now a very happy camper and am thoroughly enjoying the processor - even my wife commented that she thought it sounded better biggrin.gif
post #1082 of 2277
Hi, wondering if somebody might be able to answer the following questions about an Aventage RX-A730. I know this is not the forum, but the 730/830 forum has very little activity. The questions concern the audio settings for my Sony S570 blu-ray player which is connected to my 730 on HDMI 1 input. I have played a couple of Blu-rays which have DTS Master Audio and the only thing that shows up on the 730 display is "HDMI" and Cinema something-the surround mode is set to Standard Movie.
Shouldn't the receiver show that it is getting a DTS Master Audio signal from the Sony. I checked the settings in the Sony menu, and it is set to output DTS, not PCM. This is the way it should be, correct?
Second question-the Dynamic Range setting on the Sony can be put into either Auto or Wide. It says to set it for Auto if you are using a BD-ROM, is a Blu-Ray disc a BD-ROM? Or, should I just set the dynamic range to Wide?
Thanks for your help.
post #1083 of 2277
Originally Posted by michaelp2005 View Postfyi, a few posts back I mentioned a popping problem I was having when changing inputs etc. on the CX-A5000 Well, after some excellent assistance / troubleshooting with my dealer, including trying different processors, it turns out it's some sort of grounding problem, which I have fixed by replacing the RCA interconnects with XLR ones. Maybe the CX-A5000 is more sensitive wink.gif I will also get an electrician out to check the circuits!
Better than what, what was the base line?
post #1084 of 2277
I had a Cary 11a and it is used for Movies & TV.
post #1085 of 2277
Originally Posted by Naka View Post
What makes the volume indicator appear on the TV screen? It seems to work for all my inputs but my DVR, which I have in hdmi1.
Anyone?
post #1086 of 2277
Anyone?
You have to configure that in the receiver's menu. You can turn it off if you don't want it there.
post #1087 of 2277
I want it on. For some reason it's not showing on one of my inputs. What option am I looking for? Thanks in advance.
post #1088 of 2277
It only works for HDMI inputs.
Menu > Setup > Function > Display Set > Short Message
Its explained in the Owners manual as well.
post #1089 of 2277
It's already set to on. It works on all my other inputs except for my DVR. My DVR is in HDMI 1.
post #1090 of 2277
Could a RX-A3030 owner please do me a favor. Please post the exact model number of the big lighted remote that comes with the receiver.
I want to order one online and need the precise model #. I want to use it with my new RX-V1075 ....... (= to RX-A1030).........the 1075 was $755 on Boxing day but the remote is not nice.......the buttons are too small and close together and the remote is not back-lit.
post #1091 of 2277
Probably be cheaper to get a Harmony remote and it will control everything.
post #1092 of 2277
I just bought a Harmony 650 ($49) yesterday......have not tried it yet. I still want the Yamaha remote.........it should control things too!
This will be for my smaller family room system anyway.(got a new 50ST60 for $849 a few days ago)......theater system is in the bsmt (65ST60).
post #1093 of 2277
I recently purchased, 5 days ago a Yamaha rx-a3030 and I am impressed so far, but have an opportunity to trade in, only pay the difference on a Yamaha cx-5000 pre-amp. When I purchased the 3030 I took my Aragon 8008x5 amp in to see if it could be repaired, I haven't used it since 2009, I used a B & K for the sides. The 3030 souinds considerable better than the Onkyo.
Well the Aragon was easily repaired only $85.00 to repair it, I used it with my system for a few years with a Sunfire Theate Grand II processor, it worked well. In 2009 I changed to an Onlyo tx-nr5009 and used it until now, was never really impressed, it was ok.
My speaker setup now and then:
Speakers:
B & W Nautilus 805's, fronts
B & W Nautilus HTM1 center
B & W CDM1SE's rears
Altec Lansing ATH 2100 presence Speakers
Velodine F1500R subwoofer
Would I gain enough by changing to the cx-a5000 and using the Aragon and B & K amps to justify the cost? I understand that this question is subjective.
Any help would be appreciated.
David
post #1094 of 2277
The RX-a3030 remote model # is:
RAV423 zf72970, this info is from the remote.
David
post #1095 of 2277
Speakers:
David
...been doing some configuring to my new 3030 over the last couple days, and I see a setting for 8 ohm or 6 ohm in the menu. What is the impedance of your speakers? I couldn't find a discount on the 5000 Pre-Pro, so I jumped on the 3030 knowing that if I find the need for more power, I can always bring in my trusty Adcom five channel amp. So far, I don't think I'll need to though.
post #1096 of 2277
David
Thanks David..........it looks like it is the exact same unit that comes with the CX-A5000.
http://remotecontrolwarehouse.com/YAMAHA/ZF729700.html
It is not too expensive for me ............. I think I will likely order one. The remote with my RX-V1075 is not useful .........buttons and remote are to small.
post #1097 of 2277
Speakers:
David
I can tell you that when I switched from my Yamaha RX-A3000 to my CX-A5000 and using the XLR balanced connections I heard a definite improvement in my music. Not sure it is due to going from RCA's unbalanced to XLR balanced or just the type of DACs in this CX but man it was noticeable immediately and have felt it was well worth the upgrade.
post #1098 of 2277
A new review is available from Inside CI, The Magazine for the Custom Installer.
H/W their verdict:
Yamaha CX-A5000 and MX-A5000: Verdict
If you're looking to install a crowd-pleasing high-end home cinema, Yamaha's CX-A5000 MX-A5000 Aventage seperates should be high on your list. They deliver a level of performance that belies their price tag, delivering big screen thrills on an epic scale.
Cheers.
post #1099 of 2277
Could be mainly that it's now playing louder at a given master volume setting (the XLR outputs have higher levels than the RCAs). Unless you volume match with an SPL meter it's not a fair comparison.
post #1100 of 2277
The B & W's are 8 Ohm speakers, the Aragon 8008x5 is 200 watts per channel, weight 107 pounds and has balanced XLR inputs.
David
post #1101 of 2277
David
Here is the StereoPhile measurements of the 805's impedance curve and phase angle:
My estimate of the Nautilus 805's B-weighted voltage sensitivity was a little below specification at 85.5dB/2.83V/m. However, its impedance plot (fig.1) revealed it as being very easy to drive, with a minimum value of 4.8 ohms at 200Hz and a generally low phase angle
- Rich
post #1102 of 2277
Arg! I just realized my subscription to Stereophile has lapsed. I am way behind and will let Road and Track go away. Is the CX-A5000 in the January issue? I have renewed but missed a couple issues 😡
post #1103 of 2277
My subscription to Stereophile lapsed 15 years ago.
post #1104 of 2277
Cheers.
post #1105 of 2277
I also had that problem with my a1030.(volume not showing on dvr input) Swapped out Hdmi cable,and all was well.
post #1106 of 2277
I agree, the difference is night and day.
I have volume matched all connections and I can tell you it's a huge step up.
post #1107 of 2277
Which cable? DVR to receiver or Receiver to TV?
post #1108 of 2277
Originally Posted by marky301067 View Post
I agree, the difference is night and day. I have volume matched all connections and I can tell you it's a huge step up.
Given that the 5000 is virtually identical to the 3030 internally, then from what you're saying the 3030 is a "huge step up" from the 3000 (that the OP was comparing to the 5000).
I haven't heard either of them, I'm just sceptical of any claims of a "night and day" difference. It usually means something went wrong with the setup of one of them.
post #1109 of 2277
If it only does it on DVR then DVR to receiver. Thats unlikely to be the cause though.
post #1110 of 2277
Thanks. Thinking back I should have realized that was obvious be posting. I'll give it a shot.
