AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The "Official" Yamaha AVENTAGE RX-A1030, RX-A2030, RX-A3030 and CX-A5000/MX-A5000 Thread
The "Official" Yamaha AVENTAGE RX-A1030, RX-A2030, RX-A3030 and CX-A5000/MX-A5000 Thread - Page 19
post #541 of 2285
Originally Posted by smitty8451 View Post
I am also surprised as I did the one review and still find the unit excellent even at it's current (street) price. I have not heard the Marantz SR8801, but upon reading up on the thread I can say the CX-A5000 that I bought stays cool at all times and has not had one single issue. Not knockin the Marantz but the Yamaha is deffinitly a viable option when looking for a good pre/pro.
Smitty
I've got the Marantz AV8801, and it does run hotter than expected (I've got a fan on it just to make sure it stays cool).
The Yamaha looks like a good surround processor too, in fact, I'd been bugging Yamaha for years to get into separates, but got tired waiting for them so pulled the trigger on the Marantz last January, and am very pleased with it.
I've always like Yamaha equipment (starting with the old CA-1000 integrated amp back in 1977!
Went from the RX-A1900 (a very nice AVR) to the Marantz/Emotiva XPR-5 set up and have been quite happy with the pairing.
I'm curious about the CX-A5000 though, so have also been watching this thread for more reports on it, but oddly there have been very few!
post #542 of 2285
I do wonder if it may be two things, lack of interest or no in store demo unit at dealers (my local area dealer does not have one yet) or because it is still relatively new to the market. I pre-ordered mine just to have it by the begining of August.biggrin.gif
post #543 of 2285
Originally Posted by SvtFoci View Post
So I'd have to move up to a 2030 or a 3030? I also have the Behringer MIC2200 for my subs equalization, so would I even benefit from the sub eq in the receiver?
The Parametric EQ in the Behringer will be more precise than in the A2030 or 3030 (much more control over the centre frequency of each filter). So with the Behringer, the sub EQ in the Yamaha becomes a don't care.
post #544 of 2285
Couple of questions.
I am looking to buy the 2030. How does this new YPAO compare to the Audessey calibration.
And, I have searched, but has there been any published revies of this years RX-A line?
post #545 of 2285
Smitty
the Marantz 8801 has a LOT more buzz...even before it was released the thread was going like wildfire
Warren
post #546 of 2285
Has anyone had any HDMI handshake issues with the A3030? I installed a new A3020 today, replacing my Onkyo, and I have HDMI issues galore (green screen, corrupted video, no video/sound). I was really impressed by the DSP on a Yamaha receiver I had years ago, and I've heard nothing but praises for the Cinema HD3 on the newest models. This HDMI deal has me gun-shy, however. I'm sending the A3020 back. I'm just trying to decide whether to replace it with another A3020 (maybe I just got a dud?) or change to the A3030 in hopes that a totally different video processor might keep lightning from striking twice. It took a whole day to set everything up, realize it was glitchy, and put the Onkyo back in again. Not fun. Any opinions? And thanks.
Edited by ShakeMan - 9/13/13 at 4:40pm
post #547 of 2285
I think you may be experiencing an HDMI handshake issue. I would first start off by turning OFF HDMI CEC on the Yamaha. If that does not work, turn off ARC on the Yamaha if you are not using it, and last but not least, turn off video processing on the Yamaha. One thing I do know is if you have a 1080I/P signal feeding the Yamaha there is no reason to use video up converting/processing as the signal is digital and will be as good as it gets coming from the source device (Dish/DIRECTV boxes excluded as they pretty much have a bad pic straight from the box). I have 2 RX-A3010 and a CX-A5000 with the above mentioned settings OFF and have not seen nary a green screen. You can also try connecting one source device at a time and turn video processing ON and see which one is causing the issue. Yours is not the first time I have heard of a "Green Screen" issue so I don't believe it is a Yamaha issue, at least not in my experience.
Sincerely
Smitty
post #548 of 2285
Thanks, Smitty. I had already tried turning the ARC off (never use it anyway). I also switched the CEC off and went through each input. My BD player and PS3 never would come through, and the Roku was just a pretty Christmas green the whole time. The Dish receiver worked, but it kept popping up HDCP messages onscreen. At this point, I'm back to my Onkyo and working fine again, albeit without any nice DSP audio. I'm sending the 3020 back and trying to decide whether to get another 3020 (and hope this one was just sucky) or try the 3030. The Vida chip really helped with the block noise on Dish channels, and I notice that the 3030 doesn't have any type of noise reduction functionality. That's a bummer. Then again, totally different processor, so maybe I wouldn't have any HDMI issues. Thanks again for the post.
post #549 of 2285
Did you try turning video processing off? It's in the setup menu and kinda hard to find. Also a long shot but take the HDMI cable from the one device that worked and use that cable on one of the devices that didn't. I have read in other forums that some none high bandwidth/faulty cables can cause the issue your describing.
post #550 of 2285
After re-reading your thread, error messages regarding HDCP point to an HDMI cable issue. The recommended length for HDMI cables is 6 feet, shorter or longer cables can cause issues. I had a 4' cable that would not work one time, changed it to a 6' and all went well. Just some general troubleshooting suggestions and I wish you the best in your endevours.
post #551 of 2285
Shakeman, I've not had any HDMI handshake issues with my CX-A5000 (or other Yamana gear, for that matter). You don't mention what the other components in your system (such as TV/monitor). You may be experiencing compatibility issues between the units. Also, as Smitty suggested, I would try changing the HDMI cables.
BTW, just as a data point, when I replaced my RX-Z11 with the CX-A5000 I switched out all of my HDMI cables to the Monoprice RedMere cables. These vary from 3ft to 30ft in length and are all working great.
post #552 of 2285
Any updates on up-coming reviews? :-D
post #553 of 2285
Bwillcox
Do those new Redmere cables have the error correcting chips on both ends of the cable? I had always wondered how well they worked as I am thinking of replacing my cables and going with those. I had read that with the error correcting tech they use that cable length is no longer an issue and am looking at cleaning up my spaghetti mess of cables behind my racks.biggrin.gif
post #554 of 2285
Definitely not from me. Yamaha Canada was so angry because I mentioned that the power amp won't be able to do more than approx 65 wpc RMS all channel driven at full spectrum, they are boycotting me from doing a review of their product. rolleyes.gif
post #555 of 2285
lol - I am happy that I will pair the CX-A5000 with a Sunfire - if I decide to get a CX-A5000 :-D
post #556 of 2285
probably because its true...LOL
I seriously doubt that amp has the chops to compete well...and may only give you a little more than the a3030 can...which I assume will bench like Yamaha's 3xxx receivers of the past few years at between 60-65 watts per channel with 5 channels driven
Warren
post #557 of 2285
Yup, it's petty for any company wanting to hide the truth from their consumers. Oooh, I have to be careful, the "Yamaha Canada Police" may be watching this post (that's what he refers himself as).
The irony is that none of my post badmouth Yamaha, mostly praising them, even. The only bad "post" is when I reveal the truth about the power amp. Oh well. smile.gif
post #558 of 2285
Bwillcox
I'm not sure (I haven't taken one apart), but it appears that the chip is in only one end (the destination end as I recall) as that end is visibly larger than the other. I'm no expert on them, but I thought that the chip was used to reshape the signal, not for error correction. I do believe that the circuit in the cable has to be tuned to the length of the cable.
I wasn't having HDMI issues with my previous cables but wanted to clean up the mess I had. I really like the fact that the RedMere cables are alot thinner (esp the shorter ones) and thus allow for neater and more secure cable runs.
Edited by bwillcox - 9/15/13 at 6:51am
post #559 of 2285
You are correct, the chip is only at the receiving end of the cable, not both ends.
post #560 of 2285
I've always liked Yamaha for their pre-amp/processing capabilities...not so much for their (compared to other manufacturers) weak amplifier sections...
Best to get the CX-A5000, but pair it with an amp that actually knows its business!
post #561 of 2285
I'm truly a fan of their DSP programmes. i used to own the original DSP-A1 and a whole slew of Yamaha effects during my recording studio period of my life. They used to make truly powerful amps too. Unfortunately they are no longer available frown.gif
post #562 of 2285
I have quite powerful amps in my setup with my CX-A5000: an Outlaw Audio 7900 for the 7 main + surround channels and 4 Outlaw Audio 2200 Monoblock amps for the presence channels. However, I'm not so sure that I would say I that I need this much power. Since I also have two powered sub woofers (Def Tech Trinity Sighatures) with 2000 watt amps, each of my main and surround speakers (Def Tech BP8080STs) have 455 watt powered subwoofers in them, and my center channel (also Def Tech) has a 300 watt powered subwoofer. Probably a 'mere' 65 watts/channel from my amps would be just fine. Not sure what else might degrade (if anything), but I doubt that I'd be for want of sufficient power. wink.gif
post #563 of 2285
Hi first post here on AVS forum,
Need advice for a Yamaha receiver. I live in Montreal in a condo and i'm interested at the Yamaha Aventage RX-A3030.
For a moderated listening, is the receiver RX-A3030 is enough or too much powerful.
I do not intend to mount the volume to maximum.
Is the combo CX-A5000/MX-A5000 is a good choice or it is too much for my limited space in the Condominium.
What i am looking for is a receiver that is good for music on 2 channels and is good also for movies, television on a 5.1. audio system.
60% will be for Music and 40% Movies, tv.
Thanks for helping me on my decision and sorry if i make some mistakes on my english.
post #564 of 2285
In terms of power even the 1030 is enough for a condo (unless your condo is the size of the condo I used to live in Toronto -- 2100 sq ft)
post #565 of 2285
OK
But in terms of sound quality of the DACS on the RX-A3030.
Do i will hear a better sound with the RX-3030 vs RX-1030.
Condo where i live is 1100 Square/feet
Thanks David
post #566 of 2285
Whether you can hear the difference, absolutely. Whether it's worth the money is subjective. I'd go for the 3030 if the budget permits, IMHO.
post #567 of 2285
Go for something with XT32 instead (or maybe Dirac), YPAO is a bad joke really.
post #568 of 2285
post #569 of 2285
As my kid used to say: "YOU're a joke!" wink.gif. It's clear you never tried the latest iteration of YPAO. rolleyes.gif
post #570 of 2285
Hi, Anyone change 3020 to 3030 how's sound different from DAC.? Is it ok to change to 3030 or not?
