AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The "Official" Yamaha AVENTAGE RX-A1030, RX-A2030, RX-A3030 and CX-A5000/MX-A5000 Thread
The "Official" Yamaha AVENTAGE RX-A1030, RX-A2030, RX-A3030 and CX-A5000/MX-A5000 Thread - Page 28
post #811 of 2317
Originally Posted by nucky View Post
You are correct that's exactly what I don't like.
I am curious as well
were you running running music in 2 channel in "straight" mode or were you using one of the DSP modes and listening to it matrixed?
I dont ever listen to music in anything other than discrete channels.....so unless its SACD its 2 channel for me
That being said, that is where I find the ultra high end brands shine...not so much for HT applications
Warren
post #812 of 2317
Originally Posted by wse View Post
So does the CX-5000 and RX-A3030 sound similar?
Gosh, this is really hard for me to answer. Given the differences in the rooms that they are in and the speakers in those rooms it's hard to make a fair comparison. My living room is quite a bit larger than the den (20x22x10 feet vs. 12x14x8 feet) and the speakers differ considerably (main speakers in living room are Def Techs and in the Den I have all NHTs).
Add to that the fact that the power amps in the living room have a lot more punch than the RX-A3030. I have an Outlaw Audio 7900 300 wpc amp for the seven main channels and four Outlaw Audio 2200 200 watt amps for the presence channels. Additionally the 5 Def Tech speakers have builtin powered subwoofers (4 BP-8080STs and a CS-8080HD center) and my two Def Tech Trinity Signature subs have builtin 2000 watt amps.
All of these differences make it hard for me to make a fair comparison. Both systems sound very good to me, but I doubt I'd ever mistake which room I was listening to quality source material in. biggrin.gif
Bob
post #813 of 2317
Bob
Bob,
How do you like your CS-8080HD? I am looking at possibly purchasing one. I just ordered a CX-A5000/MX-A5000 & a Parasound A 31 combination and my fronts are Def Tech BP7001SC's.
post #814 of 2317
Originally Posted by BamaDave View Post
Bob,
I really like it. This is the first time I've owned a center channel speaker with a powered subwoofer built into it and wasn't sure what that would sound like. But it didn't take me long to decide that I like it. I find that having the low frequency response in the center channel improves dialog in movies. The people sound more realistic to me...more like they're there.
post #815 of 2317
Originally Posted by TKO1 View Post
As to whether or not Audyssey likes to have a 1.5/2.0kHz hole as their default target curve I have no idea.
Here: https://audyssey.zendesk.com/entries/410117-Midrange-Compensation
(I dont' say it's a good thing, I say it's THEIR explanation for that wink.gif)
post #816 of 2317
That Chris Kyriakakis comes across like an argent "I know what's best for you" know-all type.
I think I will stick with Yamaha.
post #817 of 2317
Bob
I would be curios if you ever switched the 3030 and use it as a pre /pro with your Outlaw and could tell any differences
Warren
post #818 of 2317
Got ya. That might have been a problem years ago with poor speaker design but with new technologies like waveguides and high order tweeter to midrange crossovers it doesn't make any sense with good engineered speakers. My speakers crossover at 3kHz for example.
Cheers.
post #819 of 2317
Warren
Not likely I'll ever do that. These things just aren't that much fun to move around and get all connected and set up. eek.gif
post #820 of 2317
Hi Folks, a question; on my CX-A5000, I have 2 subwoofers setup in front&rear configuration. I see that the second subwoofer being on is dependant on the surround program. Is there any way I can have it on by default?
post #821 of 2317
It shouldn't be dependant upon that unless there is something wrong with your speaker settings or channel levels/triggers. Check to see what all the settings are and let us know. Also, just try switching the subwoofers to a different configuration than front & rear (i.e. Left + Right, or Monaural 2) to see if that changes anything.
Cheers.
post #822 of 2317
Can you re-set it up in the speaker menu as a Left/Right configuration instead?
If Front/Rear, it may only send low frequency signals intended for the "small" surround channel speakers to the "rear" subwoofer(?).
post #823 of 2317
Thanks Bob the CS-8080HD is next on my list!
post #824 of 2317
Hi Guys, thanks for the replies. I went back and verified the config. So on music, AirPlay, I hit info on "Music Video" I can see 11 channels plus SW1 highlighted yellow, SW2 is gray. If I switch to "11 channel stereo", I then see all 11 channels plus SW1 and SW2 in yellow when I hit info.
post #825 of 2317
agreed...LOL
I was just wondering if one could hear any difference in the two...in the same setting
Warren
post #826 of 2317
Do Yamaha receivers mute the first second or two of the incoming digital audio signal until they can lock onto the signal properly? For example, when you listen to CDs over HDMI or coaxial digital input, are tracks played in their entirety or do you get the first second or two chopped off? Another scenario would be a media streamer like Squeezebox connected over coaxial or optical digital input. Do you get the first second of every track chopped off?
Many thanks for your feedback. I have found that far too many brands have this problem (Harman Kardon, NuForce, Anthem, Sherbourn, Cambridge Audio), and it's too much of a distraction once you realize that you can never hear the songs in their entirety. Surprisingly, low cost mainstream models (e.g., Denon, Panasonic) are immune to this problem. How about Yamaha?
I am particularly interested in RX-A830 to use as a pre-pro; however, there is no thread dedicated to this model. I am hoping an owner of 1030, 2030, or 3030 would be able to chime in.
Edited by sdv5 - 11/12/13 at 5:47pm
post #827 of 2317
For what its worth, I had (not too long ago!) a Yamaha RX-V1900 AVR (that was a very nice AVR BTW...), that had no such problem when sourcing the CD player's input (also a Yamaha).
I would find the problem you're describing of missing a second or so off the first of each track a real deal-breaker, no one should have to put up with that!
post #828 of 2317
I own 2 RX-A3010's and a CX-A5000 and do not experience any startup delay when playing back any audio formats. I have read in other threads that some of those described issues were rectified by firmware updates either in the source unit or receiver in question.smile.gif
post #829 of 2317
No issues whatsoever with any of my media types (Redbook CD, DVD-A, SACD, USB, HDMI) on my CX-A5000.
Cheers.
post #830 of 2317
Just to chime in here with a me-too: I've not noticed this on any of the Yamaha receivers or amplifiers that I've owned over the years. These have ranged from the DSP-A3090 many years ago to my current crop of Aventage products (RX-A720, RX-A1030, RX-A2030, RX-A3030, & CX-A5000).
post #831 of 2317
Spotify Connect, where are you?!
2 months since the anouncement (and live demo) now. I understand it already works on Pioneer AVRs that have been upgraded. Anyone "in the know" have any idea?
post #832 of 2317
Tonight, after a month of waiting, I have finally setup my 2030. What a difference between it and the RX-V1800 I was running. The YPAO is so much more intuitive and customizable. My new speakers sound fantastic. Better GUI, and easy to navigate menus.
The only issue I have come across so far is AIRPLAY.
My iPad does not show the airplay icon when playing music, but will show it for videos. .????
The only way to play music is to start a video and then switch it back to the music. Anyone else have this issue?
I will be updating the firmware tomorrow to see I'd that remedies my problem.
post #833 of 2317
Redoryx, when you say the difference between your RX-V1800 and 2030 was big, are you referring more to ease of use/setup/features, or sound (or both)? Were you running the RX-V1800 with your new speakers?
Like you, I have an older Yamaha (RX-V1700) and am curious to know if the newer Yamaha units will make much of a difference in sound.
post #834 of 2317
post #835 of 2317
Civik, yes to all of the things mentioned. I was using the speakers with the 1800. I think the biggest difference is in the YPAO. As I do not have any other calibration equipment, the newer YPAO has done a much better job af analyzing my room. With the 1800, l could not adjust the sub level as much, and the readings were harder to understand. Now, after running it 5 times last night, the subs are dialed in at -.5db. Pretty great considering what I was dealing with before. The GUI is leaps and bounds over anything the 1800 has.
Do not get me wrong though the 1800 is a very capable AVR, that I have used and loved for 6 yrs.
funny thing too, YPAO set my LCR to all large ( which they are) with a crossover at 40hz! The surrounds were large as we'll with a 60hz crossover. I have since reset them to small and an 80hz. My new PSB's sing
post #836 of 2317
But how can you really tell that the A2030 was the difference, and not your "new speakers"?
To tell for sure I'd think that you'd need to only change one part of the system at a time...rolleyes.gif
post #837 of 2317
Red, glad to hear you like the sound of the 2030 compared to the 1800. Seems like the few who have posted are happy with xx30/5000 purchase.
post #838 of 2317
I ended up getting a new package in early mid October. Set everything up except the AVR. I was having HDMI handshake issues and was waiting on new cables and adapters. I did set up all my speakers, ran YPAO on the 1800 and was enjoying them. Was using that setup for about 1 month.
Since setting up the 2030, the speakers have a whole new dimension. Hard to really out into words, but my ears are really happy:D
So in essence, my guess is the amp.
post #839 of 2317
If the speakers are the same then most of the difference is likely the setup (new YPAO), and an 1800 could probably be made to sound very similar with careful setup. Of course that's what I'd like to believe, since I have no plans to change my 1800 at the moment smile.gif.
post #840 of 2317
That makes more sense then.
I had an RX-V1900 before, that I thought was a very nice AVR (and it was), so was interested in your take on this.
(I'm running a Marantz AV8801 surround pre-pro now with Audyssey XT32 & Sub EQ, but think the new versions of YPAO are nearly as effective).
