AVS › AVS Forum › Display Devices › Ultra Hi-End HT Gear ($20,000+) › Just how close to a home Dome IMAX can I get?
post #1 of 11
Money is no object, but, let's be reasonable.
post #2 of 11
Recently Launched....
http://www.imaxprivatetheatre.com
post #3 of 11
**Jaw dropped**
I wonder if they can make a home dome IMAX setup, though. It's much more immersive, as it totally engulfs the viewer.
post #4 of 11
There are plenty of inflatable domes, that could act as a Home Imax style set-up. These are used for travelling planetaria visiting schools, amongst other applications.
Some of the high-end people here have in previous threads noted the limits to the accuracy of and imperfections in the domesurface. This may be addressed by building a fiberglass enforced dome instead.
Current warping software includes multi-projector warping and blending on dome surfaces, this has been demonstrated on multiple occassions at the Integrated Systems Europe show for a number of years now (for instance Canon had a dome to cover its booth last year, using the AVStumpfl Wings Platinum software to adapt the projection image to fit the domeshape surface).
Edited by donaldk - 5/30/13 at 4:10pm
post #5 of 11
I thought the domes were omnimax???
post #6 of 11
Very cool, thank you. Can you point me in the direction of some of these articles/videos so that I can get some ideas?
Yes!
post #7 of 11
Single projector method:
http://paulbourke.net/dome/iDome/
http://paulbourke.net/exhibition/domeinstall/
http://paulbourke.net/dome/UnityiDome/
They build their own inflatable dome, prototype dated 2009, no idea if it ever made it to commercial production: http://www.youtube.com/watch?v=_hU5W3CNCJ0.
This is the large Dome Canon has been using at shows: http://www.elementdomes.com/canon-tilted-projection-dome/.
http://www.canon.co.uk/About_Us/Press_Centre/Press_Releases/Business_Solutions_News/1H11/20110201_Canon_projectors_at_ISE.aspx
I have seen these folks from Germany at shows for a few years aswell, camerabased system for autoalignment and warping, Dataton using it with its Staging and presentation software, http://domeprojection.com/neueseite/?page_id=101.
Google for inflatable dome, dome projection and inflatable dome projection. There are many projects online from a small DIY glued together (semi-)dome above some-one's desk to 30 meter full domes.
Edited by donaldk - 6/1/13 at 12:12pm
post #8 of 11
This would be nice, and just under the 20 grand mark, not quite the imax, but prob best your going to get without purchasing an outdoor one.
http://www.ebay.co.uk/itm/IMAGE-HIGH-END-HOME-CINEMA-THEATRE-SCREEN-DENON-4520-5-1-SYSTEM-SONY-BEAMER-/251211719737?pt=UK_AudioTVElectronics_Video_HomeCinemaSystems&hash=item3a7d62a439
post #9 of 11
Thank you for your input, but, no. Absolutely not.
post #10 of 11
Interesting, but, not exactly IMAX quality. Can these even display the 70 mm film format that IMAX flosses with?
post #11 of 11
70mm is gone. Of course you could buy a pair of 4K Barco's like IMAX does. Money is no object, but 'reasonable'... There are also truly private fully immersive set-ups, that place a 'ball' around your head, you sit in the circular display, either projection from outside or inside the circular display.
  Back to Forum: Ultra Hi-End HT Gear ($20,000+)
