AVS › AVS Forum › Audio › DIY Speakers and Subs › Dayton RSS460HO-4 18" Subwoofer - Is a 3.6cu enclosure too small?
post #1 of 6
I'm working my screen redesign and in order to squeeze in four of these into the design, the aesthetics say that 3.6cu (taking into account bracing only) is as large as I can go. I can go larger but it requires me to disassemble parts of the screen wall, install the box and then put the wall back up. Not terrible during construction but if I have to remove the box in the future it will be more of an issue.
Probably not the end of the world, but wondered if getting an extra .5cu is worth the effort. I will be powering all four off a CV-5000. Thanks!
post #2 of 6
You'll be fine. You lose 1/2 db at 20 hz.
post #3 of 6
Thanks. After posting I installed WinISD. After fumbling initially .. I found it pretty easy to use and got the same results you shared. Pretty cool b/c I had some other questions about whether or not I needed that much amp and was able to model the results. tongue.gif
post #4 of 6
I have a bunch of these subs and CV5ks...four Daytons off of one CV will get you 1250W each and will absolutely slam!
How big is your room??
post #5 of 6
2600 cu ft. Dedicated HT with 1.5 inch thick walls.
post #6 of 6
Dude, 4 Daytons and a CV5k will kill in there. They are clean too
