AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Apple TV + Dual LU43PW Indoor/Outdoor Speakers + ??? Receiver = Music outside.
post #1 of 5
Alright, obviously this stuff isn't my thing. I have a spare Apple TV. Got two outdoor speakers at a garage sale. Looking for a receiver to bind them together so I can play music outside.
There's a ton of receiver options, but really I'm just looking for one with an HDMI connector (for the apple tv) and a couple channels for the speakers.
Do they make something that simple? Thanks for your suggestions. I appreciate it.
post #2 of 5
So there's nothing then?
post #3 of 5
ANY avr with hdmi in will work. You gave no budget.
You know that you will need a TV to display/navigate
The Apple TV menu?
post #4 of 5
Budget? I have a spare Apple TV and some speakers from a Garage Sale. Obviously the budget for this item would be in line with that. The least expensive option to make it work.
And no, there is no need for a TV when using an Apple TV. Everything can be controlled from an iPhone or even the computer where all the music is stored.
I'd love to find something like one of the Lepai amps. Cheap. And does one thing. But there seems to be a huge divide between a product like this and something with HDMI.
The Apple TV also has an optical audio port. Maybe theres something like that?
post #5 of 5
I see your speakers are about $30 new and ATV is about $100.
http://www.accessories4less.com/make-a-store/item/DENAVR1312/DENON-AVR-1312-5.1-Channel-A/V-Home-Theater-Receiver/1.html
If you have a computer with your music on it and can
Control it with your iPhone and know about Lepai amps
Perhaps you have a better understanding "of this stuff"
Good Luck
