AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Recommend a projector less then $1600
post #1 of 14
I am in the market for a new projector.
I have a couple that I am taking a look at.
It seems the best value is between the Optoma HD33 and the BenQ 1070.
Can someone let me know what the best one to with?
Or if you have a better recommendation feel free to share it.
Nick
post #2 of 14
I would offer a different set of choices for a budget of $1600. If you are truly trying to decide between the optima and Benq, you will find the consensus to be in favor of Benq.... with caveats.
The Benq 1070 is a great value but tends to be limited to a "short throw". In other words, most people only buy the benq with a 12 foot or shorter throw. If you are placing the projector back 15 feet, it almost cannot work unless you have a huge screen. Keep this in mind in your purchase decision.
On the plus side, it has terrific 3d and a sharp image... better in fact than the optima. I'll stop there. If you truly want to spend up to 1600, you have a lot more options.
post #3 of 14
Ok then what projector do you think I should get? I want to get the best bang for my buck... These two models just so happened to be the highest rated I have come across within my price range so far.
post #4 of 14
If you are real concerned about 3D, then the Sharp xvz-30,000 provides the best deal but it is usually $200 over that price if you get it when it is on sale. Another one is the Mitsubishi hc5 (same as hc9000d), but it is also $200 over that budget. The Sharp is much better at 3D than the Mits.
Yet another, which is only $100 over your budget is the Epson 5010 refurb from VisualApex.com. However, still $100 over smile.gif
The truth is, $1,600 is a bad cut-off point, $1,800 or less would be more realistic for a projector that also does good 3D.
If you want to forget about 3D and just focus on 2D in that price range, then the B-Stock JVC HD-250 (if you can still get them) is the best 2D projector under $1,500.
All said, it depends what you want, best 2D, best 3D, and if you are willing to buy from Ebay, etc...
If you want a good mix of dark blacks and good 3D, I'd go with the refurb Epson 5010 as it is the best of all worlds (though does have some gaming lag).
Mits hc5 = Best 2D via Ebay, not sure about gaming lag but I think it's low
Sharp xvz30,0000 = Best 3D and good 2D, I think gaming lag is too high for FPS
Epson 5010 = Best Blacks in 2D (a bit rougher due to pixel fill in bright scenes), also very good 3D but not as good as the Sharp, but lots of gaming lag
Beyond that, I would probably look at a Mitsubishi hc7800 or hc7900, but the lens isn't as sharp as some other DLP projectors.
Under $1,000, the w1070 is the king if you can fit it in your mounting range with its very short throw.
post #5 of 14
vertcobra99 you have a PM.
post #6 of 14
Agree with Coders thoughts, and add, the Benq 7000 can be had for around $1500, and would be a decent substitute for the Benq 1070, if you find the placement on the 1070 is to limited, and if you just can't quite get to the $1700ish price point for the Epson.
post #7 of 14
alright well I don't want any gaming lag because i would like to play games on this projector. Its going to be on a 120 inch screen do you still think I would have placement issues with the Ben1 1070 using that big of a screen?
when I said 1600 dollars I can realistically spend up to 2000.
just want to get the best projector for that amount of money. So if my budger was 2000 what are my options. I want good 3d and 2d plus no gaming lag.
post #8 of 14
There is no projector at $2000 or less that has the best of both attributes (2D and 3D), but the closest thing is the REFURB Epson 5010. Basically, the w1070 will have slightly cleaner 3D (better for 3D gaming), and less lag than the 5010, but all single player games should be fine on the 5010.
The lens of the w1070 will need to be placed at 10 feet to 13 feet back for 120" screen, and then you need an additional foot or two of room behind the lens (for the length of the projector itself).
It isn't so much about placement issues, the issue is usually how low the projector is mounted and how close the projector will be to the viewers' heads (the lens needs to be almost even with the top of the screen, just a couple inches above).
So keep in mind that with the w1070 since you can only place the projector about 13 feet back, then at a 1.2x seating width distance (which is about the distance most would sit at for 120" screen, some a tiny bit closer), then you would be sitting about 2.5 to 3 feet in front of the projector's maximum mounted range (so it's going to be louder than some projectors).
In short, it should work fine, and actually it works a little better with your throw distance. I would not build out the ceiling mounting area until after you've tested it on a ladder or similar to make sure the throw distance is working for you. You can also mount it on a high shelf or on a wall mount (special mount that attaches to the wall).
Edited by coderguy - 6/5/13 at 7:56am
post #9 of 14
What if I went way over my budget to the epson 5020? Does that projecter have any video game lag?
post #10 of 14
The only 3D projector discussed in this thread with semi-low lag under $2000 is the Benq w1070. There are some others under $1500, but none that would beat the PQ of the w1070 that I know. I think the w1070 is 30ms to 50ms or less, whereas the Benq w7000 is 50+ ms, the Epson 5020 is about 60ms to 65ms, and the 5010 said to be about 70-80ms.
Lag only matters in multiplayer FPS really, it can matter a tiny tiny bit in some single player games, but not much if at all.
post #11 of 14
Great Deal w/glasses and low lamp hours
http://www.avsforum.com/t/1473029/optoma-hd3300-3d-dlp-projector-w-4-pairs-optoma-rf-glasses
I have owned an HD3300 since 12/11 and it has been a great projector with zero issues. I have no problem recommending the HD3300 for a great picture and reliability. Like any projector, make sure it fits your mounting requirements for your room.
I think there is an W7000 in the classifieds as well.
post #12 of 14
post #13 of 14
I think the Sharp xzv-30000 has high gaming lag (but correct me if I am wrong), he wants low gaming lag. The Optoma hd3300 is a nice projector, but I'd give a slight advantage to the Benq w1070 overall. For 2D though, I think in some ways the Epson 5010/5020 is better than all these (for darker movies anyhow), and on a new lamp the Epson is pretty close to DLP quality in 3D for most movies, but for 3D gaming it's not good. Though honestly I don't see how people can stand 3D gaming in an active glasses setup EVEN on a DLP. Too bad the Epson also has some significant gaming lag.
I think for 3D gaming, I'm going to eventually (soon maybe) try to setup a passive 3D setup soon with 2 projectors, a Benq w7000 and JVC RS-45 at the same time (we'll see how that works). It might not work not having the same two projectors, but actually the pixels on the w7000 and RS-45 are semi-closely matched believe it or not since the w7000 has slightly larger pixels it kind of hides the MINOR convergence error of the JVC. That is why I want to try it, also since both projectors have IRIS's and lens shift, I can easily keep brightness matched and position.
However, I think I need a new screen to go behind my existing one and haven't figured out the parameters to all this yet. Even though I'm not the gamer I once was when younger, well I do think 3D does greatly add to certain games, but I also think the shuttering of the glasses ruins it. With movies your eyes are not moving back and forth as fast so the shuttering isn't as eye-fatigue causing, but I've noticed in 3D gaming eye fatigue gets at its worst.
Edited by coderguy - 6/5/13 at 11:02am
post #14 of 14
Honestly I don't watch a whole lot of 3D stuff... so 2D is more important to me. I would never do 3D gaming that would make me puke lol.
I just want it to have the ability to do 3D if I want to have a movie night with kids or something.
