AVS › AVS Forum › Audio › DIY Speakers and Subs › The Great Waveguide Shootout!!!
post #1 of 190
The measurements have started! See next post for index.
This will be a purely objective look at how the waveguides perform, Frequency Response, SPL, Off Axis Polar Response and Distortion. Due to the amount of waveguides and measurements needed it would likely be all but impossible to take all of them in one day so care will be taken to make sure the testing setup is properly configured (distances, angles, drive levels) each time.
Waveguides to be included in testing
SEOS-6, 8, 10, 12, 15,18 and 24
H290c,
QSC,
Dayton H512,
EOS-10, EOS-9?, EOS-8, EOS-6,
Denovo DW-854B, DW-774s, DW-62s, DW-654s, DW-7ES
And a few others.
Threaded waveguides will be tested with the DNA-150 along with some of the other small ones. Then most of the small and mid sized waveguides will be measured with the DNA-205 (comparable to the B&C DE10). Finally many of the mid and larger 1" waveguide will be testing using the DNA-360 (comparable to the B&C DE250). The SEOS-24 will be tested using the BMS 4594 1.4" coax.
The measurements will be done using REW (I am most familiar and comfortable with it and find it does everything I want it to) Microphone will be the Dayton UMM-6, amp will be a Audio source AMP-100, drive level will be set using a 60hz sine wave.
Baffle setup:
Edited by mtg90 - 8/5/13 at 6:39pm
post #2 of 190
Index of measurements.
Using the DNA-150 CD:
DW-62S,
DW-774S,
Smaller round unnamed waveguide,
DW-654S,
DW-7ES,
EOS-6,
Using the DNA-205 (comparable to DE10):
Measurements to come soon.
Using the DNA-360 (comparable to DE250):
Edited by mtg90 - 8/5/13 at 7:53pm
post #3 of 190
Reserved
post #4 of 190
Awesome! You mentioned this as an idea before and I'm really glad you're making it happen!
post #5 of 190
Nice, should prove to be valuable to the diy community.
post #6 of 190
This sounds really cool.
After the initial round of measurements, I'd be really interested in hearing if some extensional mode damping might affect the measured results.
post #7 of 190
Wow, Matt!
I can't believe the scope of this undertaking! We all owe you a huge debt of gratitude. Thank you so much for this and all your other contributions to the cause. wink.gif
Mike
post #8 of 190
Originally Posted by mhutchins View Post
Wow, Matt!
Mike
+1
nice work
post #9 of 190
Awesome Matt.
I'll be following along for sure.
post #10 of 190
If you are interested in trying out the 4550 with the bigger waveguides let me know and I'll send it.
I would like to see how much it is limited by the Seos 12.
Your a hard working man Matt
Thanks for your time.
Chris W
post #11 of 190
This is a great thing that you are doing for our community, Matt! When do you plan on getting started?
Do you already have the Seos waveguides? I am just curious to know if you will have to order the Seos-18 and Seos-24 and wait on them to be shipped to you from Poland?
post #12 of 190
Just remember that the same horn/waveguid can have different polar patterns when different drivers are used. THis can be VERY radical-or totally non existant-depending on the particular driver and horn combination.
It is REAL easy to read too much into a measurement of a single driver-UNLESS htat is the driver/horn combo that is actually going to be used.
I first becasue aware of this decades ago when I tried 2 different drivers (same manufacturer) on a single horn. ONe driver was VERY narrow in its coverage and the other "filled out" the horn the way it was supposed to be.
HOWEVER-when I used a different horn/type/coverage etc (same drivers) both drivers had the same coverage.
It all comes down to how well the horn./driver interaction/angles of exit and so forth "work together".
I remember hearing about a comparison back in the 80's in which Manufacturers A was saying their drivers were better than manufacturer B and they had the data to prove it. Yet manufacturer B saide theirs were better and THEY had the data to prove it.
HOWEVER the variable was that while the different drivers were being used-the horn they were placed on was made by the particular manufacturer. So each manufacturers driver perfromed better on THEIR horn-but not as good on the other manufacturers horn.
Just something to keep in mind.
post #13 of 190
Umm....SUBSCRIBED for this feast of waveguide goodness!
post #14 of 190
looks good.
post #15 of 190
post #16 of 190
Matt, if you'd like to test it I could offer up a BMS 4594 CD on an XR1464 horn.
This should be a fun comparo!
post #17 of 190
post #18 of 190
Right on !
post #19 of 190
I'll volunteer an 18Sound ND-1460A plus XT-1464. Can also send their 1.4"-2" adapter if it would be helpful (1460 becomes a 2060).
post #20 of 190
One horn that I have always been curious about is Dave Harris' Eliptrack-400 horn that is used in some Klipsch based builds such as the Cornscalla. This horn goes for almost the same as the Seos24, I believe something between $450 and $500 per pair. I never see these horns mentioned but the guys over at the Klipsch forums say they are top-notch.
post #21 of 190
Are you going to include your synergy horn in this test?
post #22 of 190
Sub'd dude!!!! Great thread!!
post #23 of 190
Looking forward to the results of this thread. smile.gif Thanks Matt
post #24 of 190
Thanks guys, but I am going to try and get through the waveguides I have before starting anymore. That said after I finish with the current round I'll likely take you up on those offers, see if there are any other waveguide or CD's someone would like to volunteer to see tested. I would not test another CD on all the waveguides unless there is a large amount of support for it due to the time it would take. I'll likely test it only on a select few waveguides.
No not going to include that one, not only is it too big and heavy to use with the same turntable but I am trying to convert them to an active/passive crossover and that is not quite done yet. I will have new measurements of them whenever I get that done but it is rather low priority.
post #25 of 190
Very cool! Sounds like there will be at least a little overlap with what augerpro was working on back in 2009. It will be interesting to cross reference the two sets of measurements smile.gif
http://www.avsforum.com/t/1148945/driver-testing-invite
https://sites.google.com/site/drivervault/driver-measurements/horns-and-waveguides
post #26 of 190
Any builds with the Denovo DW-654S waveguide out there?
post #27 of 190
post #28 of 190
Sweet! A very nice service to the members here Matt. You keep doing more and more to help in the DIY arena!
post #29 of 190
Wow. Impressive effort.
Greatly looking forward to reading more.
post #30 of 190
Ditto the importance of the matching between compression driver and horn.... it can affect distortion too.
Also, will distortion be normalized to spl? ie, eq'd flat? REW doesn't do that automatically....
