AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Where to find denon receiver firmware updates? Denon AVR-791
post #1 of 4
I just got a Denon AVR-791 off of craigslist, the previous owner said that there were firmware updates that i could install. After searching all over Denons site i couldn't find any updates for the 791. Does anyone know where and how i can update the receiver. Hopefully the UI is updated because its very confusing lol. Im waiting for my energy take classic speakers to come in tomorrow, so hopefully i can update it before then. Any help is appreciated, thanks.
I cant find the AVR-791 on denons site, so it may be that denon no longer supports this receiver which would be a shame. I also heard that the 791 is also the 1991 or something, denon changed the name apparently, i really dont know much about it since i just bough the thing.
http://usa.denon.com/us/downloads/pages/product-updates.aspx
Gear mentioned in this thread:
post #2 of 4
Why do you feel you need a firmware update? A google search a firmware update would have to be done at a repair facility. Not user upgradeable.
The AVR-791 is pretty much the same as the AVR 1911. The 1911 adds zone 2 preouts but that's about it.
I found the AVR-791 doing a Google search. Took 10 seconds.
http://usa.denon.com/us/product/pages/productdetail.aspx?CatId=AVReceivers%28DenonNA%29&pid=AVR791%28DenonNA%29
AVR-1911 on Denon site
http://usa.denon.com/us/Product/Pages/ProductDetail.aspx?PCatId=AVSolutions%28DenonNA%29&CatId=AVReceivers%28DenonNA%29&Pid=AVR1911%28DenonNA%29
post #3 of 4
I mean i already found that site for their general description of the AVR-971 just nothing about firmware upgrades for the system. My amp is acting a bit weird though, it just started happening today, when in DTS mode all the audio become muddied like not enough power is getting through to the speakers. I though a firmware update would help that.
post #4 of 4
If there was any firmware update for the 791, an authorized repair facility should be able to obtain it from Denon and install it on your 791. Check Denon's website for the closest one to you. Note however, that as the unit is out of warranty, you would likely be charged their minimum hourly labor rate for the installation ... ~$70-$90. Also Denon does not currently provide any firmware update information on their website.
http://usa.denon.com/US/Support/Pages/ServiceCenterSearch.aspx
