AVS › AVS Forum › Audio › CD Players & Dedicated Music Transports › CD/cassette combo?
CD/cassette combo?
post #1 of 13
Can anybody recommend a good CD/cassette combo player to add to my system? Looking to spend under $200. And that's the super maximum (for now). Less expensive is ideal, but don't want something that will die or eat tapes within a few years.
post #2 of 13
Bump
post #3 of 13
You will need to buy used with that budget. Check out the link below. Tascam makes some nice stuff.
http://tascam.com/product/cd-a550/overview/
post #4 of 13
I have the Marantz PMD 350, I love it but don't hardly use it as much as I used to. http://www.parts-express.com/pe/showdetl.cfm?partnumber=245-765 Currently there's one up on ebay that's in your price range.
post #5 of 13
I see the Marantz was expensive in its day. What's a fair used price these days for it? Does it have a remote? I assume it's able to be hooked up to a Yamaha receiver? Looks like these are used for professional musicians...
post #6 of 13
Well, I just got one used for $68. Oh, man, I hope it works...
post #7 of 13
Nice score. I hope it works out for you.
post #8 of 13
Congrats, you'll love it it's a great unit. Even tho I use it rarely these days, I love it too much to part with it.
post #9 of 13
I have a lot of bootlegs that I haven't heard in years. Will be nice to hear them again from time to time. I figure $68 isn't bad for not using it too often.
post #10 of 13
Dimetheos, or anyone who has the Marantz. Just got it today. Do you have rack system or is it just set up loosely? I'm wondering if I can remove the rack mount on it. Looking at it, it looks like the front panel is all one piece. If I set it up as is, it will be tilted a bit. Is that a problem? I plan to put my BD player on top of it.
post #11 of 13
Again, does anyone have an answer for my last question? Also, where on the receiver should this be hooked up to?
post #12 of 13
Hi. I have a Marantz PMD350 CD/cassette combo. The CD and tape player both seem to work, but the sound I get is terrible. Very distorted and unclear, like it's damaging my speakers. It is hooked up to a Yamaha RX-V1065 receiver, via red/white cable from "Tape+CD" on back of player to "Phono" on back of receiver. Please help. Thanks.
Thought I'd post here since the Marantz "ask a tech" isn't working for me.
post #13 of 13
Never mind. Problem solved. I'm stoopid.
